GSR Problem
Old Jun 9, 2005 | 04:30 PM
badboy58's Avatar
Default GSR Problem
So last night when I was driving home, I was shifting from 2nd to 3rd (of course in VTEC) when I released the clutch the RPM Gauge dropped all the way down to 0 and the car made a nice popping noise (coulda been a backfire), and the car was still running. So I put the clutch back in and it idled like normal. When I got up this morning, I tried to start the car and it took a second to turnover but did, and has been like that since. I have a CEL which I checked and they are a 1 and 8. Anyone know what I should look at? All the hoses are connected, timing belt is still intact, everything looks the same.
Old Jun 9, 2005 | 06:51 PM
badboy58's Avatar
Default Re: GSR Problem (badboy58)
ttt
Old Jun 9, 2005 | 06:58 PM
97tegGS's Avatar
I would try pulling plugs and whatnot. Make sure your getting the basics. Air/Fuel/Spark
Old Jun 9, 2005 | 07:53 PM
1badcrx's Avatar
Default Re: (97tegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97tegGS &raquo;</TD></TR><TR><TD CLASS="quote">I would try pulling plugs and whatnot. Make sure your getting the basics. Air/Fuel/Spark</TD></TR></TABLE>
agreed
Old Jun 10, 2005 | 05:28 AM
badboy58's Avatar
Default Re: (1badcrx)
I am going to try that along with borrowing a friends distrib and see if that helps.
Old Jun 10, 2005 | 04:38 PM
wendall19's Avatar
Default Re: (badboy58)
ya check you spark plugs and your spark cables too make sure there not worn and grounding on the valve cover
Wannabe JDM
Jul 16, 2006 03:44 PM
JDM-EJ1
Aug 14, 2005 12:33 PM
lean
May 16, 2005 06:05 PM
2000vsm
Oct 20, 2003 09:20 PM
