Gsr hesitates when accelerating
Just swapped a 01 gsr in my crx. Before the gsr i had a ls motor. The ls motor ran fine, no problems what so ever. I converted everything to 0bd1 in the gsr.
Mods: obd1 virgin p72, aem intake, oem header with a obd1 cat. The gsr runs perfectly fine until after i get on the throttle and into vtec. Engine was nice and hot when i got on it, then i felt the hesitation. In all gears, low rpms.
Ex: im in third gear accelerating slowly, i feel power then a sudden drop of power, then a few sec later i feel the power again. And as i am doing this, i kept the throttle in one position i didn't decelerate or accelerate after i felt the sudden drop in power.
Swapped over the throttle body (jdm b18b1 with adjustable tps) to the gsr intake manifold. I'm using different injectors but from another 93 ls integra (obd0) with the injector resistor i was using before.
New spark plugs, wires, dizzy cap and rotor. Timing is set to 16 btdc. Tps read .47 at closed and 4.54 at WOT.
Only thing i can think of is dirty injectors but i cleaned them before i installed them.
Any more ideas?
Any more ideas?
This is a gremlin in all GSRs. It happens to my bone stock 95 every once and a while. I personally think it's in the fuel system (call it a hunch) :D
Try doing the fuel filter.
I wouldn't think it would be my fuel filter though because i was using the same one from my ls motor. But i'll try and test it. I also kinda have a feeling it might be my fuel pump. Just a hunch as well. Still using my oem crx fuel pump. never been changed.
Morning bump.
I found out that the hesitation occurs when the engine is really hot. I was driving on the freeway for almost an hour, then randomly, i just felt the motor hesitating when i was trying to accelerate. (i was in traffic).
From: Pensacola, FL and every Court House in Louisiana
Distributor going bad possibly. I had mine feel like it would miss just a hair to where I noticed a loss in power. Swapped my distributor and never had the problem again!
I swapped b16a in my da integra.having the same problem.its hesitate when its hot.I also having this same noise in the video here.do you have these sounds?
https://www.youtube.com/watch?v=SO8B03AlA0w
Alright, just for closure, because there are so many threads on "gsr hesitation" without the solution to most of em, I found my problem (for now). So today i finally got to work on my car, i figure i swap out my o2 sensor and re-check my timing.
Not sure how this happened but my timing was off about a tooth or so. But, i haven't adjusted it yet. I swapped out my o2 sensor for another one and so far, no hesitation. Since the hesitation only occurred when my engine was hot, maybe my o2 sensor wasn't reading the temp right or something idk. I got a pic of how my old o2 looked like, but i forgot to take one of the one i put in.
I was running a ls 4 wire obd1 o2 sensor and i swapped it for a gsr 4 wire obd2b o2 sensor. Not sure if they are different in anyway, but i just thought i should get that out there. And yes my timing is still off at this point, but im trying to figure out if it was just the o2 that caused the hesitation. I'll let you guys know if the hesitation comes back.
Thanks everyone for the help!
Alright well last night the hesitation came back. My engine was warming up but not at normal operating temp. But the hesitation was always there even when my engine got up to normal operating temp.
I noticed that when i gas it partially, it hesitates. But if i gas it more than half open throttle then it goes away. Sounds like a faulty TPS sensor to me.. Can anyone confirm?
But i am going to fix my timing on friday, so i'll update you guys soon.
Alright, i fixed my timing on thursday and i've been driving since and never felt the hesitation again. Thanks again for all the help. Hope this helps someone in the future.
Back at it again.. Alright so i accidentally put regular gas instead of premium the day it came back, not sure if thats a factor in this hesitation problem. Anyways, I've been driving just regularly and hard for a week and i've never felt the hesitation until yesterday. It only happens when the engine is really hot and only after i punch the gas hard.
I was on the freeway in 4th and i punched it full throttle up till around 4 or 5k on the rpms and after that it would just hesitate under around 3k. Even when i got off the freeway it would hesitate. Pretty bad too. There was very little power when i would try and accelerate
Someone help!
Someone help!
93 should be high impedance. no box used.
other than that, check for codes. always check for codes first. there's no point in wasting a minute going in one direction, when a stored code will send you in the right direction
measure one of the injectors resistance. if you get roughly 3 ohms, then you're good. keep the resistor box. if you get roughly 12 ohms, tha's likely your problem. ditch the resistor box and rewire for high impedance injectors
