Gsr Cluster Problem
Old Oct 18, 2005 | 07:15 PM
0h teh sl0w k20!!'s Avatar
Default Gsr Cluster Problem
as ya kno i did my swap just got my cluster in from a 95 gsr. Everything is pluged in perfect and i start the car and the rpm shoots up to 5k and speedometer to 20mph. Also my gas is a little off, but not that big of a deal (i never let it go too low that i have to worry) Any input on how to fix the needles? The jump when i rev the car and drive. So its just the placement that is off. I tried searching with no definite results. Thanks
Old Oct 18, 2005 | 07:29 PM
Kendall's Avatar
Often, cluster maladies can be solved by using the film from the original cluster on the new one. Being that it came out of a 95 and your car is a 95 there should be no issues, but there's always that odd possibility.
Old Oct 18, 2005 | 08:42 PM
Default Re: (Kendall)
what exactly do u mean film? All i did was plug it in and it did that. Any way to fix the needles so they stay down on the gsr cluster?
Old Oct 18, 2005 | 09:14 PM
mjc1055's Avatar
Default Re: (integra_dreamz)
Do they ever fail to function? i.e. does your speedo ever drop to zero while driving? If so your speed sensor may be dirty, happened to me with my del sol. Give that a cleaning and see if it clears anything up.
Old Oct 19, 2005 | 06:44 AM
Default Re: (mjc1055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">Do they ever fail to function? i.e. does your speedo ever drop to zero while driving? If so your speed sensor may be dirty, happened to me with my del sol. Give that a cleaning and see if it clears anything up.</TD></TR></TABLE>
nah they dont fail they stay up there. Only thing is they dont drop unless i turn the car off. They stay at the 5k and 20mph when im idle
Old Oct 19, 2005 | 12:57 PM
hey any help.. i got the temp, rpm, and speedometer working. Now the only thing is the gas it goes all the way up high then when im driving it drops low and the low fuel sign comes on.. I just filled my tank all the way so I know my tank is full. How can i get this to stop jumping?
NoL1MiT_DC2
Jan 11, 2009 10:51 PM
honinspire02
Nov 3, 2006 05:01 PM
ronintegra
Jan 3, 2006 12:10 PM
n1neb4ll
Jan 25, 2004 01:05 PM
andrew dc
Apr 29, 2003 07:11 AM
