GSR Cluster in LS problem
Old Apr 10, 2006 | 07:44 AM
Absentmind's Avatar
Default GSR Cluster in LS problem
I swapped out my LS automatic Cluster to a manual GSR cluster because the car was converted to 5 speed and i ended up getting a gsr cluster for Free but the problem is the Gas gauge will not work i know on the JDM ITR cluster you have to swap the green backing is this the same for using a manual cluster in a automatic converted car?
thanks
-absentmind
Old Apr 10, 2006 | 07:51 AM
jdm_bones's Avatar
Default Re: GSR Cluster in LS problem (Absentmind)
I don't think you have to swap the green for this swap. I think that your gas guage is just bad...The person who had this cluster, did he say everything was working? Did he try to remove the gas guage? Some times if the needle is moved the guage is no longer good....sometimes they will be off, sometimes they wont even work...See if you can try another cluster.
Old Apr 10, 2006 | 01:22 PM
Absentmind's Avatar
Default Re: GSR Cluster in LS problem (jdm_bones)
Thanks for the quick reply!
Old Apr 27, 2006 | 03:28 PM
Dark19Acura's Avatar
no thru i have do the same thing of you i have a integra 98 with a manuel swap and the gaz dont work i want to put a type r jdm spec 96. I have change the green paper dont work 4 you juste take your GSR RPM put onyour old cluster and remove automatic light on your old cluster
digi198816
Apr 5, 2010 01:10 PM
Punkem0tion
Jul 22, 2009 04:19 PM
94eh2
Mar 22, 2007 06:18 AM
5thgencivicr
Jul 7, 2005 05:35 PM
blu3g
Mar 30, 2005 02:24 PM
