GS-R???
Old Jun 27, 2002 | 08:47 AM
bobkosu2121's Avatar
Default GS-R???
I'm thinking about buying a 94' GS-R . How can you tell the difference between a GS-R or a LS if they put a v-tec emblem on the back, changed the engine cover, and changed the intake manifold??? Thanks
Old Jun 27, 2002 | 08:51 AM
GSR95TEG's Avatar
Default Re: GS-R??? (bobkosu2121)
There is a way you can tell by the Vin # try a search I remember reading this question yesterday.
Old Jun 27, 2002 | 09:05 AM
GSR95TEG's Avatar
Default Re: GS-R??? (GSR95TEG)
Also there are no GSR auto. all 5 spd, GSR's all have wings
Old Jun 27, 2002 | 09:34 AM
b18bvtec4drteg's Avatar
My old GSR sedan dint have a wing. Its optional
Old Jun 27, 2002 | 09:43 AM
gsr9901's Avatar
look on the block or the transmission housing it should have a engine code and if it says b18c1 than it is a gs-r but if it says b18a1 then it is a ls.
Old Jun 27, 2002 | 09:51 AM
Fooser's Avatar
Default Re: GS-R??? (gsr9901)
GSR
8000prm Redline <<<<
V-tec on the valve cover
a ls has a different size valve cover all together unless its a LS/vtec
rims are alloys unless replaced.
Vin is on the block, on the bumper, hood, on the side of the door panel.
Check vin is the for sure thing. Look at multiple spots on the car to find it to make sure they are the same.
Old Jun 27, 2002 | 10:28 AM
Acronym's Avatar
Default Re: GS-R??? (Fooser)
Test drive it!
Old Jun 27, 2002 | 10:49 AM
PnX-R's Avatar
GSR hatchbacks don't have a mounted third brake light on the hatch. It's should be on the wing..
Old Jun 27, 2002 | 11:13 AM
2fastGSR's Avatar
King of the One Liners
Default Re: GS-R??? (PnX-R)
anybody who is halfway intelligent will be able to tell the difference.
Old Jun 27, 2002 | 11:55 AM
Jesse H's Avatar
here's an idea, look for the vtec solenoid?
Old Jun 27, 2002 | 12:01 PM
MaxPowerIntegra's Avatar
GSR
actually its 8200rpm redline...
Old Jun 27, 2002 | 12:15 PM
94GsRacer's Avatar
Default Re: GS-R??? (IntegraPoweR)
8100..? 8200 fuel cut?
Old Jun 27, 2002 | 12:18 PM
96_GSR's Avatar
Default Re: GS-R??? (94GsRacer)
**** my ECU is all stock and it will keep going past 8300. I don't know when it's supposed to start pinging back, but I've never seen it...Don't want to either..Is mine not working you think, or is the tach off just of a little?
Old Jun 27, 2002 | 03:43 PM
mugenracer's Avatar
Default Re: GS-R??? (96_GSR)
chances are your tach is off slightly, i have a vtec controller with rev counter and it cuts fuel at 8040, whereas the needle is at 8200, so i'm assuming my rev counter on the cluster is slightly out
Old Jun 27, 2002 | 03:58 PM
Goy091's Avatar
vin should say DC2 somewhere or DB8 if its a sedan.
LS is a DC4
LS block will say B18B1 94-01
Old Jun 27, 2002 | 04:14 PM
B-series Assassin's Avatar
You can't swap valve covers on the LS and GSR, so if it says DOHC VTEC it's a GSR more than likely.
A GSR block should say B18C1.
GSR has 8000 RPM redline.
All GSR's come in standard transmission.
There's more I can't think of now but those are the basic ones that will tell you if it's a GSR or not. You can't exactly tell by exterior or interior options because the LS SE/GS has GSR options such as rims, spoiler, leather interior. But the LS SE came out in 95-up.
Old Jun 27, 2002 | 04:27 PM
LowGSR01's Avatar
GSR redline is 8100
graham412
Jan 7, 2010 11:09 AM
hyperazn1337
Mar 7, 2005 08:41 AM
aerofreak
Aug 21, 2003 08:30 PM
Trupower
Jul 5, 2002 09:41 PM
KLN
Mar 11, 2002 09:52 PM
