Grounding problem!
Old Mar 5, 2010 | 05:04 PM
Mentat Ghola's Avatar
Default Grounding problem!
Ok, some time ago IO had a problem where the 97 GSR wouldnt start on any non-flat surface, like a hill, or a sloped shoulder on a road. So someone suggested that I clean the grounds, I did that, reinstalled them, and the problem went away for a month. Now its back, same symptoms. Car will not crank when its not level. I think again that its a grounding problem. All the wires look snug, Im thinking of buying an aftermarket grounding kit. Last time when I cleaned the grounds, the tranny ground to the frame was kinda dirty, dark grime was covering it. I wonder if thats the problem. Should I go aftermarket on the grounds?
