Ground wire question...
Old Feb 1, 2004 | 09:10 PM
Vinhtran17's Avatar
Default Ground wire question...
Does anyone know the best types of ground wires there is for my 95 ls...
Old Feb 1, 2004 | 09:12 PM
thaiphob's Avatar
Nikon!!!
Default Re: Ground wire question... (Vinhtran17)
stock.
Old Feb 1, 2004 | 09:27 PM
mr.beeks's Avatar
Default Re: Ground wire question... (thaiphob)
you really want to be suckered into those
good looking, good for nothing
dyno tested crap go ahead
waste your money...
Old Feb 1, 2004 | 09:37 PM
crazzeboost's Avatar
I saw some dyno charts in magazines are those are **** too? But isnt this mostly true for mainly turbo cars not N/A cars?
Old Feb 1, 2004 | 09:39 PM
thaiphob's Avatar
Nikon!!!
Default Re: (crazzeboost)
those mag dynos are BS.
Old Feb 1, 2004 | 09:53 PM
Ti3d in's Avatar
Your car might idle smoother with those ground kits, but I doubt you'll really gain power. You should try fabricating your own ground wire too.
Old Feb 1, 2004 | 10:48 PM
typeRSXS's Avatar
yea fabricate your own. dont pay $45+ for those
Old Feb 2, 2004 | 07:12 AM
patmcd's Avatar
Default Re: (shupaGSR)
Crap. Factory ones work just fine, aside from the ooooo look at me factor.
Old Feb 2, 2004 | 07:51 AM
Erik_Pb_Foot's Avatar
New User
Default Re: (patmcd)
going to a stereo shop and purchasing about 6 feet of 10 gauge and some end terminals for easier and cleaner installation will do the same thing that the $100 kits do.
the reason for adding ground wires would be to help smooth out your idle, mainly. the car's stock ground wires are sufficient but over time they do need cleaning at the ends or replacing if damaged. damaged ground wires will hurt the performance, minimally, but they will hurt your idle more than anything else.
verdict: worthwhile mod since it can be done for less than $20. You have nothing to loose by doing this.
Do a little searching for optimal placement of grounds as well as recommended grounding points... be it to the frame or directly to the battery.... not sure of any differences personally but i haven't researched it.... their has been quite a bit of talk about additional grounding.
Regards,
Erik
Old Feb 2, 2004 | 08:24 AM
P1mpSlap's Avatar
homemade 4ga worked fine for me.
Old Feb 2, 2004 | 09:44 AM
New User
Default Re: (P1mpSlap)
i've got 4 ga from the valve cover to the radiator support... just replaced the stocker since it was shredding at one end but adding additional ground wires will, in most cases, help smooth your idle.
Old Feb 2, 2004 | 10:27 AM
Im a friend of VinhTran so i just gonna try to resond for him, where would we go to get the supplies we need and how would we do this, thanx.
Old Feb 2, 2004 | 10:47 AM
96AllMotorDC2's Avatar
Default Re: (Erik_Pb_Foot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik_Pb_Foot &raquo;</TD></TR><TR><TD CLASS="quote">
excepte 20 bucks
Old Feb 2, 2004 | 11:21 AM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik_Pb_Foot &raquo;</TD></TR><TR><TD CLASS="quote">going to a stereo shop and purchasing about 6 feet of 10 gauge and some end terminals for easier and cleaner installation will do the same thing that the $100 kits do.</TD></TR></TABLE>
Old Feb 2, 2004 | 11:23 AM
New User
Default Re: (96AllMotorDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96AllMotorDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
excepte 20 bucks </TD></TR></TABLE>
i meant performance, reliability, maintenance wise.... smartie pants, GRRRR
-Erik &lt;--- who should take back the statement about $20 worth of supplies and say steal them from your neighbor's rice burner
Old Feb 2, 2004 | 12:03 PM
mey_xanng's Avatar
I have the Sun Auto Ground Kit.
It offers other benefits besides a small amount of power.
Like most things the benefit will depend on how bad your stock ones were. But the main difference that I noticed were first better gas milage, I use to get ~280 mile, now 300-320.
Second was whenever my CD player played sometimes it would dim a bit when cranked up, but now it never flickers, a last benefit was my car is noticably easier to start. (these things could have just been my stock wires)
You will get maximum use with them if you hook them up in series.
Also the Evo8 has Ground Wires as a factory assessory.
Old Feb 2, 2004 | 12:06 PM
New User
Default Re: (mey_xanng)
when you crank your car the start's ground is actually the engine so you are correct, and i didn't even think about that aspect. good call.
Old Feb 2, 2004 | 12:10 PM
NightRiderS2K's Avatar
In-N-Out Burger
Surprised no one has mentioned this yet: a proper and good groundwire can oftentimes help your HID (if you have one) light brighter.
NRG
Old Feb 2, 2004 | 03:58 PM
MABDOHC's Avatar
From: White Collard Crime capital of the U.S. known as S, FL, USA
Default Re: (NightRider-gsR)
****... I bought my kit for $15! Not much of a difference... but its a tad bit smoother through the power band... and better voltage through out the car.... just my 2 cents... here are my pics....
Old Feb 4, 2004 | 09:23 PM
GSteg's Avatar
Most of the honda/acuras come with 8 gauge for grounding wires.
Usually manufactors will only put out what is necessary for the car to run, because they will not waste their money to put on bigger ground wires for the modding enthusiastics.
Honda knows they can do many other stuff to the car to improve performance, but they don't because the majority of the buyers aren't going to mod their cars heavily.
Go get welding cables or power wire from a car audio shop (www.knukonceptz.com has them pretty cheap). Preferablly 4AWG is all you'll need. Anything over that is overkill and won't benefit anymore, since ground wires are very short.
Also, there are no best wires. Wire is wire. The only difference is the craftmanship in assembling the kit, and of course color if it matters to anyone.
Old Feb 4, 2004 | 09:51 PM
d16nomore's Avatar
Default Re: (GSteg)
Just make sure that you are using the right points to connect your grounds to...
Alternator housing, Tranny, valve cover, throttle body, and the MOST important...the thermostat housing (ECU main ground)
And, I'm gonna have to disagree with mey_xanng. My tests showed better results when you tied all of the points back to a common point. I saw a lot of voltage fluctuation when connected in series(like between .5 and 1 volt)
When the kit is installed using the right points, you are making the charging system more efficient so the alternator is dragging the crank less.
You are also providing one stable voltage to the sensors.
Finally, the problem with the stock system, is that it is the minimum grounding necessary, nothing more. There are gaskets, sealant, seams and paint all through the engine bay.
Sorry, a little long...I've put some work into the subject...and it definitely made a diference in my DA9...
Old Feb 5, 2004 | 03:53 PM
ggangtong81's Avatar
Default Re: (d16nomore)
is anybody willing to make one for me for 45 shipped?
Old Feb 6, 2004 | 11:02 AM
hotintegranights's Avatar
Default Re: (ggangtong81)
summit racing sells a nice braided ground wire the one that goes from the valve cover to the upper rad support for 5 bucks if anyone like to know.
Old Feb 6, 2004 | 07:16 PM
Default Re: (hotintegranights)
i need new grounding kit cuz my old ones are all rusty..and need a replacement...anybody making one?
Old Feb 9, 2004 | 09:36 AM
d16nomore's Avatar
Check in my sig for what I offer...
