ground controls?
Old Feb 21, 2009 | 01:54 AM
BoboyRS's Avatar
Default ground controls?
i just purchased ground controls for my 94 LS and 2 coil overs are long and 2 of em are short. the long ones have a number i'm thinking its the spring rate but the 2 long ones have "200.64.58" and the 2 short ones are "180.64.44". are they supposed 2 be like this or did i get ripped off? and what do those numbers mean? if they are supposed to be like that, which ones go in the front and which go in the bak? hoping for some answers thanks
Old Feb 21, 2009 | 02:13 AM
AWD Terror's Avatar
Default Re: ground controls?
I would guess the longer ones go in the front to counter balance the weight of the engine and keep the car level. However, I don't know. Your best bet would be to look it up on their site, or call and ask them.
Old Feb 21, 2009 | 02:20 AM
425_Booster's Avatar
Im drunk too. So Im just agreeing. Sounds good.
Old Feb 21, 2009 | 08:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The first number is the length, second is the diameter, third is the spring rate. Those are metric measurements.
200.64.58 = 200mm length, 64mm diameter, 58 kg/cm = 8" spring, 2.5" dia., 325 lb/in spring rate.
180.64.44 = 7" spring, 2.5" dia., 250 lb/in.
Sounds like the GC Special Editions, i.e. the standard kit for Integras.
taimysho0
Nov 18, 2008 12:16 PM
InTegraLS_2001
May 4, 2004 04:27 PM
GasHuffer
Jan 10, 2003 11:58 AM
edz92tegrs
Feb 27, 2002 10:35 PM
