ground control for koni
From: You can be my wingman anytime...., Las Vegas, US
You need an adaptor from Ground Control, that fits on the coilover. It's specific to which shock you are using. I think they are like $50.
If you already have GCs, you can get the inserts from GC, or you can special order them, made to fit the Konis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inteGSR »</TD></TR><TR><TD CLASS="quote">does anyone know if the koni ground controls are for koni yellows and reds, or only yellows?</TD></TR></TABLE>
To answer your question, they are only for the yellows. The reds have the spring perches welded on like stock or any other shock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
To answer your question, they are only for the yellows. The reds have the spring perches welded on like stock or any other shock.</TD></TR></TABLE>
Thanks. that's the question i was asking. they should be more specific - they only say koni's. so i will order the ground controls for stock shocks.
this one will work right?
http://cgi.ebay.com/ebaymotors...85660
.brad
Suspension & Brakes
Sep 14, 2005 02:54 PM
