Grinding 3rd sometimes?
Old Nov 2, 2003 | 07:31 PM
94B18B1Teg's Avatar
Default Grinding 3rd sometimes?
94 integra LS, 133,000 miles. I don't get what the hell is going on....but sometimes when I hit third as easy as possible, it grinds, and other times it doesnt. The other night I chirped 3rd no grind. Sometimes I'll just be like regular cruising, shift into 3rd at about 4000, it'll grind, so I drop it back down in second, and try again, this time I put the clutch to the floor, and completely let off the gas, and it still grinded, but if I pull it out back into neutral, then back into 3rd, nothing. I don't get this ****, oh yeah, I've had the car for about 3 days, and I just crossed over from domestic to import. sooooo is this something I should be usual with, or do I need a new tranny in the near future?
Old Nov 2, 2003 | 07:34 PM
LSTEG96's Avatar
Default Re: Grinding 3rd sometimes? (94B18B1Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94B18B1Teg &raquo;</TD></TR><TR><TD CLASS="quote">94 integra LS, 133,000 miles. I don't get what the hell is going on....but sometimes when I hit third as easy as possible, it grinds, and other times it doesnt. The other night I chirped 3rd no grind. Sometimes I'll just be like regular cruising, shift into 3rd at about 4000, it'll grind, so I drop it back down in second, and try again, this time I put the clutch to the floor, and completely let off the gas, and it still grinded, but if I pull it out back into neutral, then back into 3rd, nothing. I don't get this ****, oh yeah, I've had the car for about 3 days, and I just crossed over from domestic to import. sooooo is this something I should be usual with, or do I need a new tranny in the near future?</TD></TR></TABLE>
ok, first off...about the post ***** thing... honestly, im sorry
https://honda-tech.com/zerosearch &lt;-- use this (domestics pff! )
ull easily find that u have synchro problem... no need to waste time now!!
Old Nov 2, 2003 | 07:47 PM
IntEGNYC's Avatar
Default Re: Grinding 3rd sometimes? (LSTEG96)
the grinding may be attributed to running with low clutch fluid. Since you say its only happens in 3rd, it may be due to your syncros needing replacement. no need to have a new tranny. Just having the syncros replaced will do.
Old Nov 2, 2003 | 08:10 PM
IntegraXTR's Avatar
check the fluid levels...
also it might be the syncros
Old Nov 2, 2003 | 08:18 PM
P1mpSlap's Avatar
Throw some GM synchromesh in there.
Should fix it for a while.
Old Nov 2, 2003 | 09:24 PM
oMek's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">Throw some GM synchromesh in there.
Should fix it for a while.</TD></TR></TABLE>
make shure its friction modified version
Old Nov 2, 2003 | 09:37 PM
1998_4dr_gsr's Avatar
I've had this problem before...turns out its bad syncros. I've had this problem with my old prelude and my EG. Better get it fixed asap or you wont be able to get into any of your gears. Rebuilding the tranny would prob cost over a grand, pending on location. The parts are cheap, but its the labor that'll cost. Also, change your tranny fluid to Honda MTF, see if that'll fix the problem. If not, its time for new tranny. Hope this helps.
punkxassxbiker
Jan 15, 2008 07:44 AM
crxowner
Nov 18, 2006 02:34 PM
.doeboyfresh.
Feb 20, 2005 10:20 AM
FireMedic
Jul 17, 2004 12:19 PM
Snydog0510
Jul 29, 2003 10:00 PM
