Grindage from 2nd to 3rd
Old May 14, 2004 | 01:54 AM
sQwiReL bOi
Guest
Posts: n/a
Default Grindage from 2nd to 3rd
Hey i was wondering if any of you guys are having the same problem as i am with my tranny. i have a b18c1 and I just recently changed out the clutch, flywheel, and diff. I have an ATS 1.5 lsd... for some reason when i shift from 2nd to 3rd it likes to grind, but it goes in all the way. it only grinds when i am at high rpms..., and im pushin the clutch in all the way. any of u guys have the same problem or know wat im doin wrong? thxs
Old May 14, 2004 | 06:58 AM
GS'D YA's Avatar
Community Builder
Community Influencer
Default Re: Grindage from 2nd to 3rd
Yeah, I've got the same problem. Let's give a huge shout out to worn out syncros!!
Old May 14, 2004 | 07:05 AM
yakiroba's Avatar
Default Re: Grindage from 2nd to 3rd (Ntegd Ya)
Make sure you're not using gear oil in your tranny:p Sometimes using Redline will fix small grinding problems.
Old May 14, 2004 | 07:20 AM
frenchy's Avatar
Default Re: Grindage from 2nd to 3rd (VTEC is not a crime!)
same here - i heard if you jam it in enough times it will wear down the synchro and not grind anymore - ghetto fabulous
Old May 15, 2004 | 01:39 PM
Rod.'s Avatar
Default Re: Grindage from 2nd to 3rd (frenchy)
it is the syncros. I had it from 2nd to 3rd on my Ls.
Old May 15, 2004 | 02:22 PM
AlphaKennyWun's Avatar
Default Re: Grindage from 2nd to 3rd (redturbocivic)
I just started noticing that problem on my LS tranny.
Old May 15, 2004 | 02:26 PM
E-brake or Handbrake's Avatar
Default Re: Grindage from 2nd to 3rd (Turbo Chris)
Major grinding from 1st to 2nd, 2nd to 3rd, and finally sometimes 3rd into 4th grinds as well. My tranny pwnZ me
Old May 15, 2004 | 06:16 PM
deviusdragger's Avatar
From: im nothing from no where im no one at all, ca
Default Re: Grindage from 2nd to 3rd (Inconclusive)
yeah bro my gsr does the same thing. It grinds when i shift it from 2nd to 3rd gear but at high rpms like 7600. only when like i race which is not really often. What are some recomendations for this? any suggestions would be awesome. thanks.
Old May 23, 2004 | 05:40 AM
sQwiReL bOi
Guest
Posts: n/a
anymore ideas? i forgot to mention i have synergyn 5 30 fuild in the tranny.... i was too poor for the ATS tranny fluid. could that be a possible reason?
Old May 23, 2004 | 06:23 AM
gsrboi80's Avatar
Default Re: Grindage from 2nd to 3rd (sQwiReL bOi)
that happened to my buddys SI the syncros were bad in third. It was under warrenty so honda fixed it.
Old May 29, 2004 | 11:34 PM
Gerbilo's Avatar
Default Re: Grindage from 2nd to 3rd (gsrboi80)
mine grinds going into 5th if i'm shifting into it from 2nd or 3rd... which is when i'm running it hard then laying off to cruise in 5th... if i'm not revving hard and normal driving it won't grind. I just double clutch it from low gears to 5th... I think it's the syncho, I figure i'll get it fixed sooner or later, got a shitload left on my warranty.
DJ4Jesus77
Honda Civic (2001 - 2005)
10
Oct 8, 2010 08:57 PM
infamouskillas
May 17, 2008 09:56 PM
94~GSR
Aug 1, 2006 12:43 PM
EdBoon
Apr 25, 2004 06:02 PM
Radon_03
Apr 10, 2004 05:30 AM
