gotta big problem need help
Old Mar 28, 2006 | 08:35 PM
WhoDoYouThink's Avatar
Default gotta big problem need help
ok, here's the deal... I just got home and noticed that the vacuum line to the FPR was split in half. The car was running fine, well somewhat with the exception of a shitty idle, and I am not sure how long it was split like that either.
Now when I put a new vacuum line on the FPR and connect it to the IM the car dies almost instantly. I played with the idle screw and ended up having to take it out to get it to hold the idle.
I am just wondering what the hell is causing it to do this to me because i want to fix it now.
Old Mar 28, 2006 | 08:37 PM
kraig8's Avatar
without the vaccume hose on the fpr you will run max fuel pressure. reconnect the new vaccume hose. then reset your ecu. let your car idle for awhile it should fix the shitty idle.
Old Mar 28, 2006 | 08:39 PM
Default Re: (kraig8)
do i still reset even if i am using Hondata S200? and how do i reset it?
Old Mar 28, 2006 | 08:42 PM
kraig8's Avatar
just unplug the negative terminal on the battery. let it sit for about 10 seconds. then reconnect it. you were wiggin out your ecu becuase of the higher fuel pressure.
Old Mar 28, 2006 | 08:44 PM
cool, i'll try it right now. thnx a million man. i'll be back in a few minutes and let you know how it goes.
Old Mar 29, 2006 | 08:14 AM
Default Re: (WhoDoYouThink)
well, that didn't really do it much either. any other ideas what it may be that is causing my car to idle like ****.
Old Mar 29, 2006 | 06:35 PM
anyone else have an idea about what the hell is causing my car to idle like complete ***? I just need it to hold a friggin idle when it is warmed up. It just keeps wanting to die, I think it may be that i am getting too much fuel, but I dont have a pressure guage and I have 12:1 c/r so I would rather it be a lil rich than a lil lean. ya know.
Anyway, please give me some ideas.
Old Mar 29, 2006 | 06:40 PM
ghostrider dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 &raquo;</TD></TR><TR><TD CLASS="quote">just unplug the negative terminal on the battery. let it sit for about 10 seconds. </TD></TR></TABLE>
do that and take out the ecu fuse for ten secs....
it might work.
Old Mar 29, 2006 | 06:46 PM
Default Re: (ghostrider dc2)
how is taking out the fuse any different than just unplugging the neg terminal?
I'll give it a shot, but do you care to explain why?
Thank for the advice tho.
Old Mar 29, 2006 | 06:54 PM
just unplug both the neg battery , and the fuse for the ecu.(for more than ten secs )
im dont really have a specific answer for that.
but when you wanna reset the ecu thats how you do it.
it works for my car allways...
hopefully works for you too.
Old Mar 29, 2006 | 07:01 PM
b20integrapower's Avatar
well..i believe their suggestions were the right ones..and would have fixed your problem..but u adjusted with the idle adjust screw..so now ur idle is probably off, even though u reset the ecu
Old Mar 29, 2006 | 07:17 PM
did it work?
Old Mar 29, 2006 | 07:18 PM
Haleiwa-Brando's Avatar
Default Re: (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">well..i believe their suggestions were the right ones..and would have fixed your problem..but u adjusted with the idle adjust screw..so now ur idle is probably off, even though u reset the ecu</TD></TR></TABLE>
Might I add, that your supposed to adjust your idle screw WHEN the car is at proper running tempurature.
Old Mar 29, 2006 | 08:25 PM
Default Re: (Haleiwa-Brando)
i did adjust it right after a 30 min drive last night and it was running so bad the idle screw didnt do anything for me.
Old Mar 29, 2006 | 09:41 PM
tegman85's Avatar
any signs of runing rich? like black smoke
Old Mar 29, 2006 | 10:05 PM
SlamminS85's Avatar
Default Re: (tegman85)
to reset your ecu, unhook the POSITIVE terminal, then re-enter the car and hit the gas pedal once and the brake pedal once, wait for 5 minutes, then hook everything back up and start the car and do not touch the gas or brake pedal for about 5 minutes, you will hear the car change its idle speeds but thats normal
Old Mar 30, 2006 | 06:07 PM
Default Re: (SlamminS85)
thanks man, btw... how the hell does bhittin the gas and brake aid in resetting the ECU?
Old Mar 30, 2006 | 07:25 PM
SlamminS85's Avatar
hitting one of them (I dont remember which) will create a connectiuon and help discharge any electricity ramaining in the Capacitors in the ECU or elsewhere in the car.
Old Mar 30, 2006 | 08:22 PM
well if it is electrical related i would guess it would be the brake, as that is the only one that has anything to do with electricity. all the gas pedal does is pull the throttle cable.
Well regardless, I will give it a shot and see how it goes. Thanks for all the help man.
boostedb20ek
Dec 11, 2009 12:52 PM
Jsarv
Mar 12, 2009 01:15 PM
211811518
Sep 18, 2006 04:15 AM
Dr. Gonzo
Jan 12, 2004 03:53 PM
raene
Nov 8, 2002 06:38 PM
