Got A ? On Pistons??
Subscribe
May 4, 2008 | 07:31 PM
Well I am about to order CTR pistons for my gsr and people are telling me that the pistons WONT match with the rods and the other half are telling me they do?? What is the truth here.. I have a gsr and wanting to put ctr pistons in it for a N/A car..
and question 2 is on this list here is this everything i am going to need to make this complete
CTR B16B High Compression Pistons.
Full Race Engine Gasket Kit.
NPR Performance Chrome Rings.
High Strength 9310 Steel Wrist Pins.
ACL Rod and Main Bearings.
ACL Thrust Washers
Head Gasket (Cometic)
Exhaust Manifold Gasket
Intake Manifold Gaskets (Hondata)
Valve Cover Gaskets and Seals
Oil Pan Gasket
Front Main Seal
Rear Main Seal
Spark Plug Galley Seals
Camshaft Seals
Camshaft Plug
All O-Rings
Exhaust Seals
Water Pump Gasket
Racing High Tempature Valve Stem Seals
Oil Strainer Gasket
Oil Pump O-Rings
Modified by DougGsrHatch at 10:17 PM 5/4/2008
Reply 0
May 4, 2008 | 08:49 PM
Re: Got A ? On Pistons?? (DougGsrHatch)
come on guys!!! i am wanting to buy these tonight and i am wanting to know if this is the right kit...
Reply 0
May 4, 2008 | 09:59 PM
you could always go with Itr pistons... will match right up and will provide you with higher compression,... that same company sells them.... the b16b pistons should work too may require some slight machine work but either way will work, the itrs would be the easiest upgrade., are u using the stock rods??? if so the pins will need to be pressed out, let us know whats going on
Reply 0
May 4, 2008 | 10:00 PM
Re: Got A ? On Pistons?? (g2daturbo)
yes i am going to us stock rods.. but what will my compression be.. cause i have a fully built head and now working on bottom end..
cause with the B16b pistons it will put my compression to 12:40:1
and also trying to think what all i will have to upgrade so i dont hurt nothing..
Modified by DougGsrHatch at 11:17 PM 5/4/2008
Reply 0
May 4, 2008 | 11:04 PM
dont go with the pct pistons, im doing a similar build, i decided the best oe honda pistons would be jdm itr pistons.
play with this:
http://web.archive.org/web/200....html
btw u are better off using oem piston rings
Reply 0
Subscribe
