Glove Compartment problem
Hey guys, i took out my glove compartment box to give me more room to run my wires for my new cd player. The Cd player installation is finished and is perfect, however I can't put back the glove box.
Can somebody open their box and show me where the screws go in. I'm having trouble fitting it in there.
thanks in advance.
thanks in advance.
your talking about the glove BOX, right??? if so, I am not quite sure why you would have taken that out to do much of anything. But if you did take it out, on the bottom corners of the back of the glove box you will find two screw holes on each side...those are attached to the metal bracket that spans from the center console to the passenger side door side of the dash. Just take a minute to look at it, they match up pretty well!?!?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinb20vtec »</TD></TR><TR><TD CLASS="quote">your talking about the glove BOX, right??? if so, I am not quite sure why you would have taken that out to do much of anything. But if you did take it out, on the bottom corners of the back of the glove box you will find two screw holes on each side...those are attached to the metal bracket that spans from the center console to the passenger side door side of the dash. Just take a minute to look at it, they match up pretty well!?!?!</TD></TR></TABLE>
I only owned the Teg for like 2 weeks, so i realized that I didnt need to take the box off after I did. however, i know it's simple, but for some reason i can't get it to hook up right. I'll take some pics this afternoon to show you what i'm talking about. The metal part keeps on falling off after i screw on one side.
I know what you are talking about, about the metal part falling off...test the screws before you use them and make sure they are the right ones...it's really easy to get the interior screws/bolts mixed up as to where they go...just test what you got and make they're right...you should have 3 bolts with a phillips screw driver part as well as the 10mm head, and one either straight 10mm bolt or phillips head screw.
ok, her's an update as to what is wrong: When I screw the glove box in, it doesnt close flush. It is like it is sitting up too high. No mater how hard I push (within the limits of breakin it) it wont even catch the latch. It is kinda like the left corner of the box is sitting crooked, but I cant really tell. When I pull on it, the left side screws come out of the holes. I will get you some pics later. Please let me know if this was any help.
Thanks for all your help so far
jondaurio
Feb 9, 2014 07:06 PM
TehMoonRulz
Jul 13, 2006 05:41 PM
