Getting serious on the mods
Old Dec 18, 2001 | 02:20 PM
speedymon's Avatar
Default Getting serious on the mods
Ok people I'm saving up money to take my car to the next level. I wan't to go all motor and I know what i want to get. I just don't know what brands can you help me fill in the blanks? I have a 96 GSR w/ bolt ons, FPR, S2 cam gears, VAFC. I going for a street racing setup with around 11.5 compression.
ecu-
cams-CTRs or Toda As
springs and retainers-
pistons- ITR (if it will bump compression)
headgasket- mugen
intake mani- s2 if neccesary
I don't know if i left anything out. I'm new to the internal side of things. Any suggestions?
Old Dec 18, 2001 | 02:37 PM
Isaac's Avatar
New User
Default Re: Getting serious on the mods (speedymon)
[QUOTE]Ok people I'm saving up money to take my car to the next level. I wan't to go all motor and I know what i want to get. I just don't know what brands can you help me fill in the blanks? I have a 96 GSR w/ bolt ons, FPR, S2 cam gears, VAFC. I going for a street racing setup with around 11.5 compression.
ecu- Type R ECU for cost/Hondata/Apexi/AEM's new one?
springs and retainers- If you plan on using CTR cams, and keep a redline of 8400 Type R S&R's should be fine. But if you want to upgrade get Titanium Retainers and Toda/Jun springs.
headgasket- mugen (Considered Spoon's?)
intake mani- s2 if neccesary (Huge midrange gains when tuned if using more aggressive cams)
Use the search feature though, you'll learn a lot. Just research each part individually and find out what best fits your needs and then if you have specific questions then ask away. Good Luck either way!
Old Dec 19, 2001 | 07:31 AM
speedymon's Avatar
Default Re: Getting serious on the mods (98 GS-R)
thanks alot man. that helped me out. I used the search feature but everyone had a different set up and different goals. Couldn't find one to suit me. I need to build around the cams cause that will determine my S&Rs, ecu and pistons. I don't want to worry about clearance problems.
Old Dec 19, 2001 | 07:58 AM
chri5's Avatar
It sounds like you only want to do a mid level all motor build. Here is what I would do if I were you, and in fact this is what I was originally going to do.
1. Toda A's w/ the valvetrain to rev to 9200
2. Toda/spoon/SMS Header Whichever one wins the Great Header test
3. Pistons to raise the Comperssion to 11.5:1, I don't recall which ones would do it since it has been a hella long time since I was going to do this.
4. Skunk2 IM
5. HomeMade Comptech IceBox
6. Comptech Exhaust, Just because I like the way it sounds on an AllMotor car.
7. Comptech 6.7lb Flywheel
8. ClutchSpecialties Stg 2, Although any non6 puck clutch would do.
9. Either JDM 4.78 FD or the ATS 4.9 Final Drive.
10. Hondata stage2 nonBoost
That would be a pretty cool setup IMO.
edit-Had to add number 10
[Modified by Strng1dah, 8:59 AM 12/19/2001]
Old Dec 19, 2001 | 12:31 PM
speedymon's Avatar
Default Re: Getting serious on the mods (Strng1dah)
when would i have to worry about clearance problems? when i get a thinner gasket and pistons? I've been reading up on that and there don't seem to be any winning combos? which pistons and headgasket.
Old Dec 19, 2001 | 12:37 PM
GSRwBOOST's Avatar
damn...
screw it.. go all turbo... you'll be much more satisfied with the power gain.. and it's just as relaible as any all-motor debt project... just dont get boost happy..
Old Dec 19, 2001 | 10:23 PM
speedymon's Avatar
Default Re: Getting serious on the mods (GSRwBOOST)
Hmm. I think i would though. Can't i get a turbo and just run low boost on stock internals?
Old Dec 19, 2001 | 10:26 PM
hybrider's Avatar
ya of course, but with that comp, i wouldnt go above 6psi daily driven
egmaster1797
Dec 15, 2003 02:43 PM
JumbosGS-R
Apr 29, 2002 02:36 PM
ZeRo
Mar 12, 2002 07:01 PM
BlackGSR
Jan 29, 2002 06:23 PM
ActiveAero
Oct 25, 2001 05:24 AM
