Getting code 21 over and over, resetting ecu fixes it
Old Jun 13, 2004 | 07:47 PM
tremor86's Avatar
Default Getting code 21 over and over, resetting ecu fixes it
I have a 96 ls that I just put a 96 c1 in. I am getting a code 21 for the vtec solenoid. When I reset the ecu, it erases the code and the vtec will work. Then after running for awhile it will throw the code again and the vtec wont work. Every time I reset the ecu, it fixes the problem. Is there a possible short?
Old Jun 13, 2004 | 08:14 PM
timmy8151's Avatar
Default Re: Getting code 21 over and over, resetting ecu fixes it (tremor86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tremor86 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 96 ls that I just put a 96 c1 in. I am getting a code 21 for the vtec solenoid. When I reset the ecu, it erases the code and the vtec will work. Then after running for awhile it will throw the code again and the vtec wont work. Every time I reset the ecu, it fixes the problem. Is there a possible short?</TD></TR></TABLE>
If the code is coming back again and again, you're not really fixing the problem. You should try to get to the root of the problem.
Try checking your plug or check your valve. Do a search, there are a lot of threads about people throwing a Code 21.
Old Jun 14, 2004 | 02:02 PM
tremor86's Avatar
Default Re: Getting code 21 over and over, resetting ecu fixes it (timmy8151)
The car runs perfect when it works correctly.When it isnt throwing a code 21, it throws a code 1 for the primary oxygen sensor. Last night it would fix it when I reset the ecu, now it doesnt fix the code 21 when I reset it. The car has a brand new solenoid and pressure switch. Im running a p28 with a boomslang harness and had to repin the wires to a4 and d6. Suggestions?
Old Jun 15, 2004 | 05:58 AM
ebola_one's Avatar
Maybe check your oil level? I had codes 21 & 22 when I'd inadvertantly let the oil level drop too far
Bit of a long shot, but you never know.
Old Jun 16, 2004 | 09:10 PM
tremor86's Avatar
Default Re: Getting code 21 over and over, resetting ecu fixes it (ebola_one)
oil level is totally fine... gonna check for continuity tommorrow
tavo.760
Dec 17, 2013 10:22 AM
EGh22aEG
Mar 18, 2002 04:18 PM
boost killz
Sep 7, 2001 10:59 AM
