Gauges
Old Oct 4, 2007 | 04:46 PM
uglybanter's Avatar
Default Gauges
I just bought an integra and there is a lot of stuff wrong with it, but that's not the point lol, how much would it normally cost a mechanic to reconnect the gauges on the dash board? Right now the only thing that works on the dash board is the tach but the gas gauge and the speedometer don't work. any one have any quotes for me?
Old Oct 4, 2007 | 05:06 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Gauges (uglybanter)
You are assuming that the problem is in the gauge cluster. You had better look at the wiring in that car closely to see if it was hacked. The average mechanic will want nothing to do with this job.
Old Oct 4, 2007 | 06:40 PM
BlueIntegraBoy's Avatar
Default Re: Gauges (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You are assuming that the problem is in the gauge cluster. You had better look at the wiring in that car closely to see if it was hacked. The average mechanic will want nothing to do with this job.</TD></TR></TABLE>
Rewiring is such a PITA.
Old Oct 4, 2007 | 07:08 PM
EnjoyTheRideDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglybanter &raquo;</TD></TR><TR><TD CLASS="quote"> how much would it normally cost a mechanic to reconnect the gauges on the dash board? Right now the only thing that works on the dash board is the tach but the gas gauge and the speedometer don't work. </TD></TR></TABLE>
Does the temp gauge not work as well?
The gauge cluster plugs in using 3 plugs (2 for the gauge assembly and 1 for the SRS system)
Any shop will charge you an arm and a leg just because they assume its a lot of work...but it might be an easy fix.
Old Oct 7, 2007 | 06:39 PM
uglybanter's Avatar
well im kind of going to a shop that specializes in jdms and my friend's dad owns the palce and he may give me a discount, im not sure if the temp gauge works or not but ill check in the morning on my drive to school
Old Oct 7, 2007 | 06:49 PM
UmbraDc2K's Avatar
It's a simple job to take out gauge clusters, just a few screws. I'd say do it yourself and plug them back in, it's hard to mess up plugging up a cluster. If the speedometer doesn't work after that check your speed sensor.
Old Oct 8, 2007 | 09:22 AM
uglybanter's Avatar
Default Re: Gauges (UmbraDc2K)
thanks guys oh yea and the temp guage doesnt work either lol
JDM_rolex
Jul 23, 2006 11:49 AM
Tuesdaynightfever
13
Jul 1, 2005 09:12 AM
ilovemydc2
Nov 18, 2004 10:04 AM
