funny idle
Old May 3, 2003 | 09:26 AM
2k1_ITR_0736's Avatar
Default funny idle
my car when it semi warms up has a nasty idle problem. it varies from 1000-2300 rpms ina cycle. also when i step on the gas, the car hesitates. sounds like its running on 2 cylinders..
btw it my 91 gs auto
Old May 3, 2003 | 10:17 AM
M-Type's Avatar
Default Re: funny idle (2k1_ITR_0736)
maybe a dirty air filter
Old May 3, 2003 | 01:50 PM
intekragsr's Avatar
Default Re: funny idle (M-Type)
Dirty or clogged IACV. to test it,
locate the IACV (on top and behind the intake mani with 2 coolant lines and 2p harness)
warm car up to reg temp
pull the harness off while car is running, and if the engine does not stall or fluctuate in rpm, your IACV is clogged or dead.
First pull the valve off, spray the screen and the other hole with carb cleaner. Drench it.
Then put it back on and test idle.
Or check for vacume leaks
Old May 4, 2003 | 08:15 AM
Default Re: funny idle (intekragsr)
hrm, cool. ill try it today
Convoy
15
Jan 22, 2020 04:54 PM
byronl
Jun 14, 2006 08:26 PM
mean_1
Jul 30, 2004 06:30 PM
1.8t
Oct 19, 2003 04:34 PM
CRXhf90
Oct 1, 2002 01:58 PM
