full throtle shift
is full throtle shifting ok for your your car? ive never done it but ive heard its ok is you shift quick (of course only at the track).01 ls, stock clutch.
You'd need a ECU, or some kind of control box, to do it. Hondata has it as a feature. They use a rev limiter to drop the revs on gear changes so you don't have to lift.
no, it's retarded.
i still give a little gas when i shift, but only enough to make the rpm drop slower, and by then, the rpm is exactly where i want it for the next gear. makes for a nice, smooth, seamless shift.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">it's more than risky. it's stupid.
listen to him.
</TD></TR></TABLE>listen to him.
I do it all the time on my other beater teg. Once you get good at it, you won't ever hit the rev limiter no matter what RPM you full throttle shift it at. It is a little rough on the clutch tho, depedning how well you can do it.
It may be stupid to some, but it works if you get it right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg racer 877 »</TD></TR><TR><TD CLASS="quote">is full throtle shifting ok for your your car? ive never done it but ive heard its ok is you shift quick (of course only at the track).01 ls, stock clutch.</TD></TR></TABLE>
Its ok, if you do it right. It will put extra stress and wear on the clutch though.
Personally, I just try to rev match on both upshifting and downshifting, but I don't drag race my Integra either. I had a 700 whp, 14:1 compression ratio 6.0L V8 in a Vega back in high school for that.
watch those gears.
</TD></TR></TABLE>watch those gears.
Hondaz_Son02
25
Oct 15, 2007 02:12 PM
