Fuel Pump HELP......!!!!! Please
Old Dec 27, 2006 | 07:00 AM
SlammedBlackGSR's Avatar
Default Fuel Pump HELP......!!!!! Please
I have a 95 integra gsr (which is running a code for the check engine light), i pulled into a mcdonalds last night in a parking space (ideling with the ebrake up) to eat my food and my car idels alittle bit under 1 grand, bogged down and then went back up and then bogged down again and shut off.........tried starting it again and it wont start.......it turns over and im gettin spark from the plugs.....and my main relay is good b/c my check engine light clicks and turns off when the key is at the ON possition..........my buddy came up and helped me out he said its the fuel pump, he didnt hear it humming when u try and start the car............could that be it? is there anyway i can start the car? also is it hard to install? thank you for your help
Old Dec 27, 2006 | 07:36 AM
Integra_drk's Avatar
Default Re: Fuel Pump HELP......!!!!! Please (SlammedBlackGSR)
is it aftermarket? How much gas did you have in your tank? Could be the fuel pump. Its not that hard to replace, just gotta pull out the back seats and its pretty straightforward from there.
Old Dec 27, 2006 | 08:49 AM
Default Re: Fuel Pump HELP......!!!!! Please (Integra_drk)
i was on empty i went to sunnoco to get gas and got a full tank and drove for about 20 minutes on that tank and now it dont start...........no it's the stock fuel pump....thanks alot tho
Old Dec 27, 2006 | 08:51 AM
but it ran fine before you filled up? weird. sue the gas station and tell em they sold you shitty gas.
Old Dec 27, 2006 | 08:52 AM
yeaaa it ran fine before i went and started right up after i filled it up.............yooo thats a good idea......ill hook u up wit some free gas
CrazyHigh625
Jun 19, 2012 01:33 PM
Mora Long
May 10, 2010 07:08 AM
D'PEXi
Apr 7, 2009 07:41 PM
jefftron
Mar 1, 2007 08:43 PM
gnar kill
Nov 18, 2005 02:09 PM
