Fuel Problem?
Old Oct 26, 2008 | 06:55 PM
highonimports95's Avatar
Default Fuel Problem?
My teg is a 96 gsr Jackson Racing super charged. I recently had new seals put on my head and some valves replaced. The car was running fine at the time but ever since i got the seals redone and new valves put in my car hasn't wanted to run right. When i start it up its bogged down real bad and it wont rev up, i have to kinda tap on the gas till the rpms get higher then i can just hold the pedal down. When i try to drive it i have to rev it up pretty high to get it going otherwise it will just die. and when i shift i have to stay in high rpms as well. After i come to a complete stop it will die then wont start up, i have to let it sit for a min or to. That's what makes me think its flooding its self but i don't see why i would have this problem after just having the valves replaced and getting new seals. I've been told by two different people that build cars and one says the supercharger is messed up and the other just says i need to get a fuel pressure regulator and lower the pressure. i am open for any opinions so please post them. Thanks.
Old Oct 26, 2008 | 08:13 PM
kronikSLOW's Avatar
Default Re: Fuel Problem? (highonimports95)
have you tuned your car since the install? this could be the reason. check your air fuel ratio.
Old Oct 26, 2008 | 10:10 PM
Default Re: Fuel Problem? (kronikSLOW)
nope i havent had it retuned. Was told i shouldnt have to, but im starting to think they were wrong.
Old Nov 2, 2008 | 05:39 PM
bump
laopadak303
Honda CR-V & Element
Jul 21, 2012 07:41 PM
blk007
Jul 10, 2007 05:56 PM
RaVAGE00
Jan 24, 2002 08:21 PM
