Front and rear O2 sensor...any difference?
Old Jan 5, 2004 | 01:49 PM
speedymon's Avatar
Default Front and rear O2 sensor...any difference?
Any difference in the outputs of these O2 sensors? This is for a 1996 GSR.
Old Jan 5, 2004 | 01:55 PM
boost fed ls's Avatar
Default Re: Front and rear O2 sensor...any difference? (speedymon)
yes, the front controls stuff like a/r,ect. and the back is just mainly to tell if the cat is doing its job.
Old Jan 5, 2004 | 03:59 PM
XtremeCarTuner's Avatar
Default Re: Front and rear O2 sensor...any difference? (boost fed ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls &raquo;</TD></TR><TR><TD CLASS="quote">yes, the front controls stuff like a/r,ect. and the back is just mainly to tell if the cat is doing its job.</TD></TR></TABLE>
Couldn't say it any better....
Old Jan 5, 2004 | 04:46 PM
speedymon's Avatar
Default Re: Front and rear O2 sensor...any difference? (XtremeCarTuner)
Yeah i knew that much. But i was thinking maybe they both have the capable of the same outputs but it's the ecu that computes the differences because of the cat. Basically what I'm asking are the o2s interchangable since they are both 4 wire or do they read the exhaust gas differently.
Old Jan 5, 2004 | 05:39 PM
i believe they are different
Old Jan 5, 2004 | 07:40 PM
Devlins 91LS's Avatar
I believe they're physically the same
however the primary can't be hooked up to the secondary pin-out and vice versa. but i'm pretty sure they're the same.
Old Jan 5, 2004 | 08:09 PM
quikB18B's Avatar
Default Re: Front and rear O2 sensor...any difference? (Devlins 91LS)
Ill make a long story short
When we were doing my turbo install, my primary o2 sensor was accidently damaged when the header was removed. Since i was not going to run a cat I had no use for the secondary, so I made a thread prior to using it to make sure it would work.
My friends/memebers told me it was the same.
I used it(secondary) as the primary and It works fine
Old Jan 5, 2004 | 08:25 PM
96dc2's Avatar
Default Re: Front and rear O2 sensor...any difference? (quikB18B)
They are both the same and function the same, just has different purposes as stated above. The only difference is the length and the 2nd/rear one has a grommet for the hole in the floorboard. Yes they're interchangeable.
And yeah, if you disconnect the 2nd O2 sensor it won't affect performance at all.
Modified by 96dc2 at 8:19 AM 1/6/2004
Old Jan 5, 2004 | 09:24 PM
speedymon's Avatar
Default Re: Front and rear O2 sensor...any difference? (96dc2)
That's what i thought. Glad someone could confirm it. Thanks alot.
GSR_integra
Dec 3, 2007 10:25 AM
sickofitall1113
Aug 30, 2007 02:00 PM
boostincoupe
Aug 10, 2005 02:40 PM
deadlock32
May 28, 2005 11:03 PM
dohc-nyne
May 4, 2003 08:56 PM
