front end noise
Old May 7, 2004 | 06:14 AM
BB2H23A1
Guest
Posts: n/a
Default front end noise
i have a noise in fron end that is like a dragging noise, almost sounds like tires on fender wells but it isnt i checked the cv joints and they are in good shape any ideas
Old May 7, 2004 | 06:17 AM
VTECorona's Avatar
Default Re: front end noise (Hybridumbidiots)
Is your car SLizAmmed y0? Does this sound happen at a certain time or is it constant?
Old May 7, 2004 | 06:38 AM
BB2H23A1
Guest
Posts: n/a
Default Re: front end noise (VTECorona)
its dropped 2.5" on skunk2's goes way when turning its aligned and everything correctly
Old May 7, 2004 | 07:01 AM
VTECorona's Avatar
Look at the plastic fender liner and look for where it's been rubbed. My integra rubbed mine when I bottomed out occasionally. It showed smoothed streaks from where the tire rubbed it.
Old May 7, 2004 | 10:02 AM
xplanetearth420x's Avatar
check the scrape gaurd on the front bumper
after i dropped my car i cut it off bc it was scraping on everything
Old May 8, 2004 | 03:25 PM
BB2H23A1
Guest
Posts: n/a
Default Re: front end noise (xplanetearth420x)
after some more driving i noticed it goes away when i go on the crown or hump in the middle of the road, i checked my camber with the pole position tool and it was
-3degrees on both front tires, i am wondering if it could be a wheel bearing or possibly a tire deffect
Old May 8, 2004 | 04:44 PM
crawdad689's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">check the scrape gaurd on the front bumper
after i dropped my car i cut it off bc it was scraping on everything</TD></TR></TABLE>
ditto.
Old May 9, 2004 | 08:54 PM
diogo6's Avatar
Default Re: front end noise (crawdad689)
have you checked your bumper... you could find a lot of info on "cars for dummies"
It's on sale for 9.99
Old May 9, 2004 | 09:13 PM
Keno20's Avatar
I had a similar problem. It sounded as though my cv's were stuffed. It turned out that my plastic steering rack gaurd was abit torn and sticking out and every time I turned hard right it would rub.
Old May 14, 2004 | 12:31 AM
Boosted-LS's Avatar
Default Re: front end noise (Keno20)
i got the same problem , i didnt happen when i got my 15" rims on my car with 195/55/15 , however now i got 16" on my rims and it reads 205/50/16, could this be due to the size of the tires? my car is low but i've only lowered it like 1.5" and it still makes alot of noise, please help!
Old May 14, 2004 | 04:49 AM
BB2H23A1
Guest
Posts: n/a
Default Re: front end noise (Kid-X17)
this isnt something dumb like a splash guard rubbing it is chassi related i took off the cv joint boots and they looked good, i am wondering it if is maybe the wheel bearings. its not dragging a bumper or rubing the fender wells, it is deffinatly a chassis issue
Old May 14, 2004 | 04:53 AM
n0 iNTegRiTY's Avatar
check scrape guard on the front bumper and the lining on the wheel well.... I've had trouble with both of those.
Old May 14, 2004 | 09:59 AM
Boosted-LS's Avatar
Default Re: front end noise (n0 iNTegRiTY)
ok, thanks ill check em and let u know what happen
Old May 14, 2004 | 11:26 AM
Bay_707's Avatar
I have this exact problem only mine sounds like a heat shield rattling in the engine bay, and i dont have any heat shields.
Old May 15, 2004 | 10:02 AM
Default Re: (Bay_707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bay_707 &raquo;</TD></TR><TR><TD CLASS="quote">I have this exact problem only mine sounds like a heat shield rattling in the engine bay, and i dont have any heat shields.</TD></TR></TABLE>
hmm.... perhaps the infamous header rattle....
Is it only in between a certain rpm? if so, then I'd say its the header.... do you have aftermarket?
EDIT: Just looked at your sig
ArtyTheKid
Jan 24, 2015 04:41 PM
scartail
Aug 19, 2011 12:27 AM
tunes12
Apr 20, 2007 07:08 AM
jdmda9
Nov 30, 2005 03:33 PM
codyb13
Apr 14, 2005 05:41 PM
