freeway rpms
Old Aug 30, 2006 | 12:16 PM
2000dollarzcbs's Avatar
Default freeway rpms
im on the freeway doing 70 at 4700 rpms. whats the best way to fix this? new tranny? opinions please.
Old Aug 30, 2006 | 12:21 PM
HGZ's Avatar
HGZ
Default Re: freeway rpms (2000dollarzcbs)
switch to 5th gear? j/k
Old Aug 30, 2006 | 12:46 PM
Default Re: freeway rpms (HGZ.)
91 gs, stock motor. thats why. ouch.
Old Aug 30, 2006 | 12:59 PM
Johnny_Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000dollarzcbs &raquo;</TD></TR><TR><TD CLASS="quote">im on the freeway doing 70 at 4700 rpms. whats the best way to fix this? new tranny? opinions please.</TD></TR></TABLE>
something doesn't sound right. its a b18a right? 5 speed? auto?
Old Aug 30, 2006 | 01:10 PM
Default Re: freeway rpms (JohnnyH)
5 speed.
Old Aug 30, 2006 | 02:13 PM
gogogomoveit's Avatar
u need to look into that tranny. I dont think its stock.
Old Aug 30, 2006 | 02:23 PM
red91g2's Avatar
Default Re: freeway rpms (gogogomoveit)
i just switched from auto to 5 speed and in the auto i was at like 3000 at 70 mph and now with the 5 speed im at probably around 4000 with a ls trans you might have a b16 trans or something but that 4700 is way to much man, look into that!
Old Aug 30, 2006 | 02:54 PM
GoldCoin's Avatar
max speed on b16 tranny 115. hated it. had to downshift 4th instead of 3rd.
Old Aug 30, 2006 | 02:59 PM
lVlemphizStylez's Avatar
Default Re: freeway rpms (DC TWOin IT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC TWOin IT &raquo;</TD></TR><TR><TD CLASS="quote">max speed on b16 tranny 115. hated it. had to downshift 4th instead of 3rd. </TD></TR></TABLE>
on what redline??? not to 6800 or 7k....because my b16 definately went higher than that
Old Aug 30, 2006 | 03:06 PM
projectTeG's Avatar
hows the clutch? because thats seem hella high on everything stock, i was at about 3k on my stock ls tranny at 70mph.
Old Aug 30, 2006 | 03:09 PM
GoldCoin's Avatar
Default Re: freeway rpms (lVlemphizStylez)
i had mine on an ls with ls ecu.
Old Aug 30, 2006 | 07:13 PM
i JUST had the clutch replaced 4 days ago.
Old Aug 30, 2006 | 07:22 PM
JDM_DC4_Fanatic's Avatar
&lt;sarcasm&gt; Check your V-teck fluid resivoir &lt;/sarcasm&gt;
Old Aug 30, 2006 | 07:44 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000dollarzcbs &raquo;</TD></TR><TR><TD CLASS="quote">i JUST had the clutch replaced 4 days ago.</TD></TR></TABLE>
what transmission are you using?
Old Aug 30, 2006 | 08:30 PM
MugenDC4's Avatar
im not sure tats even a b16 tranny. I'm running a b16 tranny right now and i'm around 4200 @ 80mph. 4700rpm for me would probably be around 85-88. Possible tach is off?
Old Aug 30, 2006 | 08:32 PM
Default Re: (MugenDC4)
all tachs are off...mine is off by 500 rpm's
Old Aug 30, 2006 | 08:38 PM
Default Re: (lVlemphizStylez)
i dont think the tach is off, cause at 70 mph, my motor sounds like it is seriously hurting, and i hate it, cause then i have to drive 60 to make me feel better, and then im THAT guy on the road.
Old Aug 30, 2006 | 08:41 PM
Default Re: (2000dollarzcbs)
cruising at 4500 rpm on the road wont kill your engine...
Old Aug 30, 2006 | 08:42 PM
SlammedDC2's Avatar
Semper Fidelis
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000dollarzcbs &raquo;</TD></TR><TR><TD CLASS="quote">i dont think the tach is off, cause at 70 mph, my motor sounds like it is seriously hurting, and i hate it, cause then i have to drive 60 to make me feel better, and then im THAT guy on the road.</TD></TR></TABLE>
I hate that guy, but for me usually there are 2 of them right next to each other.
Old Aug 30, 2006 | 09:46 PM
DC2 Mang's Avatar
Default Re: (SlammedDC2)
sounds like a b16 tranny, i was at around 4500 rpms going 70mph
my friend is around 3700 at 80 in his 91 ls
Old Aug 31, 2006 | 08:46 AM
projectTeG's Avatar
id say the tachs off, because evem if it was a b16 tranny you wont be sittin that high at 70...you would at 80.
Old Aug 31, 2006 | 09:41 AM
DA is best's Avatar
if it is a b16 tranny just get a ls 5th gear put in it
Old Aug 31, 2006 | 02:25 PM
Default Re: (DA is best)
the engine could be revving even high if the tach is off, its not always showing a higher rpm.
Old Sep 1, 2006 | 08:42 PM
Default Re: (JDM_EK_Fanatic)
actually, weird enough. my axels broke and after i replaced them, its at 3800 rpms at like 72.
edubfromktown
Sep 14, 2010 11:32 AM
Ddep1085
Sep 4, 2004 01:29 PM
CleanLIttleLude
May 12, 2003 03:58 AM
Ronin Integra8
Apr 2, 2003 08:15 PM
Pakman
Mar 28, 2003 05:53 PM
