FOGGING
Old Feb 28, 2002 | 02:51 PM
SYDNEYSIDER's Avatar
Default FOGGING
When you windshields fog up inside, how do you clean it. Cleaning it with dry cloth doesnt seem to work and I hate it when the fog marks appear during daytime. I use the screen wipes and they work O-K.
Old Feb 28, 2002 | 06:50 PM
PnX-R's Avatar
Default Re: FOGGING (GS-R_ocks)
I use Rain X Anti-Fog on my GSR and it works wonders!.. You can find it at your local auto parts store..
Old Feb 28, 2002 | 06:58 PM
Default Re: FOGGING (PnX-R)
But I use to use RainX and it only takes 2 days until it fogs up inside again. And when it does, I'm ususally left with runs.....
Old Feb 28, 2002 | 09:18 PM
nfn15037's Avatar
Is it Rain-X in the yellow bottle, or RainX ANTI FOG in the black bottle??
Old Feb 28, 2002 | 09:25 PM
Chris's Avatar
Default Re: FOGGING (nfn15037)
Here might be some helpful hints to avoid window fogging.
When you use the AC make sure you turn it off, but keave the fan blowing for the last 5 min of your trip, avoid using it on short trips.
AC does work well to de-fog windows (it naturally de-humidifies the air, and also is good for allergy sufferers).. BUT see above.
Avoid wiping it when its fogged up, just wait and it will clear up, the car has(should) be warmed up anyway.
Make sure you are not introducing moisture (more than normal) into the passenger area of the car, such as water leaks...heater core leaks.. etc.
HTH
Old Mar 1, 2002 | 12:46 AM
au-gsr's Avatar
Default Re: FOGGING (Chris)
i use newspaper to clean my windows(no lint) also if your windows are fogging up a lot and it rains a lot in your area check the sppare wheel compartment. i have a 94 teg and the rear tail light seals(made of foam rubber) were leaking into the trunk. i had over two galllons of water sloppin around back there. check it out.
Old Mar 1, 2002 | 04:42 AM
PnX-R's Avatar
GS-R_ocks, I don't know about you but.. I've put that stuff on my windshield 2 months or so ago and it's still working.. Now the driver/passanger side and rear windows, that's a whole different story.. I figured that I just need to add more on them..
nfn15037,as for which bottle I use.. I bought the black one..
Old Mar 1, 2002 | 05:08 AM
slowerthanu's Avatar
New User
I never get the runs from Rain-X anti-fog. I do however often get the runs after I eat a McRib.
Old Mar 1, 2002 | 06:48 AM
samagon's Avatar
I turn on my a/c and put it on defroster.
usually, fog inside my car means really humid, and the a/c is a dehumidifier.
Old Mar 1, 2002 | 08:44 AM
neo1z's Avatar
Default Re: FOGGING (samagon)
thats what i do
Old Mar 1, 2002 | 08:50 AM
Chris's Avatar
Default Re: FOGGING (neo1z)
but make sure you turn it off and leave the blower on for a few minutes, or there will be moisture in the lines...and just make it worse next time you turn it on. Not to mention the car will start to stink after a while (musty, mildew smell)
Old Mar 1, 2002 | 11:56 AM
Rain_man's Avatar
New User
And also from heavy breathing...
Old Mar 1, 2002 | 08:39 PM
Vazquez911's Avatar
Typically when my windows fog.... I let them fog... it's a signal to peeps outside to not come a knockin!
Try the fog-x stuff... it works!!
lastzodiac
Nov 7, 2005 02:53 PM
Kyles ej1
Jul 16, 2004 06:17 PM
pbcdb
Audio / Security / Video
17
Jan 17, 2004 09:42 PM
gsr.sedan
Jul 16, 2001 12:21 AM
keithv
Jun 14, 2001 06:44 PM
