fluid
Old Jan 29, 2006 | 05:33 AM
petergriffen's Avatar
Default fluid
how do i change my transmission fluid? does he car have to be level or what? much aprecciated.
Old Jan 29, 2006 | 06:12 AM
Racermech's Avatar
Default Re: fluid (petergriffen)
Search, This has been covered many times.
As you only said transmission, I will assume you have a manual tranny"
Car should be as level as possiable, remove the drain bolt (3/8 drive bolt low on the tranny) remove the upper filler bolt. Let all the old fluid drain out, replace the lower bolt. Fill with 2.3L of honda MTF. If you search you will find another method of filling the tranyy through the VSS on top of the tranny.
ocdcivic
Dec 11, 2004 10:11 AM
2lobes1engine
26
Jun 29, 2004 08:27 PM
Brett
Jun 26, 2003 08:56 PM
EF-9SiR
Nov 29, 2002 11:15 AM
EVIL Hx Coupe
Oct 29, 2002 09:05 AM
