Fluctuating Voltage - Please Help!!
I have a 2000 GSR with only a few mods (I/E/H, OBD1 ECU) and my voltage of the entire car fluctuates. It happens when the car is wamed up. Often it is linked to RPM or acceleration but not 100% of the time.
When the RPM is high, the voltage of the entire car is around 13.7 - 14V. When I'm at idle or in neutral, it is around 11.6 - 12V. But again, the fluctuations don't always correlate with this.
IDEAS ANYONE???
IDEAS ANYONE???
Test voltage at batt. posts, should be 12.5V, engine not running, 13.5V engine running, up to 14.5V engine RPM up.
Do the same tests with meter pos.(+) probe on batt. post and neg.(-) probe on cars chassis, [studs ob shock tower], if voltages are diff. check the main grounds, batt., batt. to chassis, chassis to engine.
Most batt./alt shops will to a batt./alt./charging, [load] test for free, it only takes a few min. 94
CrxChicken
Dec 24, 2014 02:25 PM
reasonable rock
Engine Management and Tuning
Oct 15, 2012 07:47 PM
nicklp60452
Jul 14, 2008 02:53 AM
dwc7276
Jan 29, 2007 08:33 AM
acura, car, cars, del, fit, fluctuates, fluctuating, fluctuation, fluxuating, honda, linked, sol, transmission, voltage, voltages
