feeling slugish!!
Old Jun 30, 2005 | 11:28 AM
veilsides2000's Avatar
Default feeling slugish!!
i just have a simple question. My car a 94 integra gs-r is feeling sluggish. like it feels like it doesnt make much power through out the whole power band. IT used to pull harder . i just want to make sure what it may be. i know my clutch is going out. it slips here and there but mainly when i got to WOT. also its been prety hot lately. you guys think its my clutch not gripping that hard anymore or do i need a tune up or something? sometimes when i hit vtec the clutch starts to slip. it mainly slips when it hot out or if i drive hard. MY car feels like i'm towing a boat or something behind my car. the pedal is really soft and it is a stage four clutch. MODS ARE LISTED in my SIG. thanks again guys any help is appreciated
Old Jun 30, 2005 | 11:31 AM
patdemps's Avatar
Default Re: feeling slugish!! (veilsides2000)
Well there isn't any mods in your sig. But first take a compression test...how many miles on your car?
Replace your clutch if its slipping.
Could be a number of things. Check your normal maintenance and make sure all your fluids are good. Very hot and muggy days take there toll on a car and its more difficult to breathe....could be a number of variables.
Old Jun 30, 2005 | 11:40 AM
Default Re: feeling slugish!! (patdemps)
where can i get a compression test done???
MODS: intake, skunk2 intake manifold, skunk2 chipped p28 ecu, fludyne radiator, removed air contidioning, removed power steering, stage four clutchmasters clutch, test pipe, ground control coilovers, if i remember some more ill let you guys know
Old Jun 30, 2005 | 11:43 AM
91500 miles
patdemps's Avatar
For starters im surprised you have a Skunk2 IM without opening up anymore power with atleast a header/exhaust setup. Maybe some ITR cams.
You've probably lost some low end torque...
Go to any parts store for auto parts. Buy a compression tester. Follow the directions...do it for each cylinder and see what your numbers are. Then, post them on the site. We will tell you how your engine is doing.
Old Jun 30, 2005 | 11:51 AM
yeah i know im working on getting a hold of a jdm itr header, tiR exhaust system, with some skunk2 stage 2 cams with valve train, and some ctr pistons to bump up compression. but you dont think it could be the clutch or just a simple tune up?? im going to test the compression. what numbers should it be at???
Old Jun 30, 2005 | 12:16 PM
anybody else have anything to add?? thanks again guys
Old Jun 30, 2005 | 04:27 PM
Irish Integra's Avatar
The car will of course be sluggish if the clutch is slipping because the engine is not turning the gearbox properly. You are losing torque because of the slipping clutch, hence the feeling of towing a boat. First do the clutch and then if the car is still not pulling look into it further.
WalkerGSR1
Mar 22, 2009 08:06 AM
R81_DC2
Nov 14, 2008 07:59 PM
Eddie99
Honda S2000
Nov 19, 2007 06:56 PM
Jaewon
Jan 13, 2004 12:23 AM
brucie
Jul 12, 2003 11:23 AM
