fan problem
Old May 11, 2008 | 06:52 PM
hifl's Avatar
Default fan problem
I tried searching but it says server is down. Any ways, my fans will run even when my car is turned off. Only way they do not run is if i disconnect my battery. Is this a common problem or normal?
Old May 12, 2008 | 07:24 AM
tegb20's Avatar
Default Re: fan problem (hifl)
Your mechanic who ever that may be made them direct meaning they run straight from the battery. Your fan switch probably blew and so they did that so they would at least turn on and not let your car over heat. Its not really bad just that your fan motors will burn out much quicker and might have to replace them in a few months. Just take it to a shop and tell them whats wrong and its done. Its quite easy to fix unless they tore or broke the plug.
spens 91 Ef
11
Apr 14, 2009 05:59 PM
manny81
Apr 22, 2007 12:23 PM
G2ILS
Jan 19, 2005 10:34 AM
TheHeyta
Feb 18, 2003 01:53 PM
