explaination
Old Sep 16, 2001 | 11:23 AM
unKnown's Avatar
Default explaination
i was at the track yesterday with my old g2 teg and somebody was trying to explain to me why my car was hopping at the starting line but i didnt quite get it
he told me to launch higher but i'm thinking if i launch higher wouldnt i hop more?
i'm running 16 inch toyo t1-s with about 35 psi in each tire, i launched at around 3k and my car was like hopping so bad that my air freshener flew at me heheh
should i launch maybe higher? or should i keep it at 3k and loose some air in my tires
Old Sep 16, 2001 | 11:48 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: explaination (unKnown)
It's called "Wheel Hop" and it happens when the suspension cannot hold the power to the ground.
Now, there's a few reasons for this, not necessarily all reasons......
1- You got just too much power
2- Your suspension is in dyre need of replacement
3- Your launching too high a rpm
You can remedy this by.........
Improving your suspension setup
Install traction control bars
Lower your launch RPM
Install a limited slip diff
I'm sure theres much more than what I just listed, but there's a start for you.
HTH
Old Sep 16, 2001 | 03:05 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: explaination (B18C-EJ1)
You can install polyurethane motor mounts but your car will shake at idle.
LightningTeg
Oct 22, 2012 09:52 AM
Jdmintegr
Suspension & Brakes
Jul 31, 2011 07:39 PM
avio
Apr 24, 2010 11:19 PM
Jxi8s2k
Suspension & Brakes
Mar 30, 2006 12:39 PM
egb18c5
Suspension & Brakes
25
Dec 9, 2005 08:15 AM
