Exaust causing mess
Old Nov 2, 2005 | 10:10 PM
atmosphere's Avatar
Default Exaust causing mess
on my 98 gsr....with a new motor in it...72,000 b18c1.......aemcai.....greddy exaust...the rear bumper of my car and wing have black ish all over it....its hard to wash off but u gotta put pressure on it? anyone know whats causing this mess? i know the exuast yeah...but it passes smog n stuff. wat else can i look for? whats wrong with it?
thanks guys.
Old Nov 2, 2005 | 10:57 PM
Dartanian's Avatar
Default Re: Exaust causing mess (atmosphere)
Sounds like you are burning oil. I had the same issue with accumulating gunk on my bumper and it turned out it was going through a few quarts a week because of bad rings.
I would get a leakdown and compression test to confirm.
Old Nov 3, 2005 | 07:01 AM
93_teg_CT's Avatar
Default Re: Exaust causing mess (Das Schmoo)
Iunno, I just had my engine fully rebuilt. Everything was replaced. then put a new JDM spec 4-1 header, carsound cat, and an rsr ex-mag and after 200 miles I've noticed that too. Well, maybe mine was burning everything since it was new... but iunno lol.
Old Nov 3, 2005 | 10:29 AM
Dartanian's Avatar
Default Re: Exaust causing mess (93_teg_CT)
It must have been built wrong. Obviously, the rings didn't seat, so there must be a problem with the clearances, procedure putting them in, or your tuning.
There is no reason that a freshly rebuilt should smoke, so something wasn't done correctly.
Old Nov 3, 2005 | 10:38 AM
SYTFU Tommy.'s Avatar
he just answered his own question.....the carsound cat doesnt work as well as a oem cat.....
1turbodc2's Avatar
agreed, shmoo is a good buddy of mine and he knows what he is talken about!
Old Nov 3, 2005 | 10:39 AM
oilguzzler's Avatar
can the rings be the culprit of burning oil on a b18c1 even when the compression is at the 210's for all 4 cylinders?
Old Nov 3, 2005 | 10:42 AM
1turbodc2's Avatar
Default Re: Exaust causing mess (oilguzzler)
yes it can be
Old Nov 5, 2005 | 11:29 AM
oilguzzler's Avatar
Default Re: Exaust causing mess (gssr)
How so?
Old Nov 7, 2005 | 10:39 PM
atmosphere's Avatar
what can i do to stop this? and burning what rings?
Old Nov 7, 2005 | 10:40 PM
JDM-EJ1's Avatar
Sounds like you're burning oil which is causing all the mess from your exhaust.
Old Nov 8, 2005 | 07:35 PM
atmosphere's Avatar
Default Re: Exaust causing mess (JDM-EJ1)
what can i do to prevent this?
Acura850.
Feb 11, 2009 12:18 PM
Smith bPr
Jul 28, 2007 03:14 AM
atmosphere
Nov 8, 2005 12:25 AM
piotrush
Aug 5, 2005 11:42 PM
baddboy
Mar 29, 2003 08:57 PM
