engines
Old Aug 2, 2004 | 05:15 PM
jinteg730's Avatar
Default engines
are all vtecs 1.7 liter and if so why are they so much better then just the dohc 1.8 liter
Old Aug 2, 2004 | 05:51 PM
skunk2eg's Avatar
Default Re: engines (jinteg730)
the 94+ tegs come stock w/ 1.8L vtec (b18c)
i don't know about "so much faster" but it has to do with the variable valve timing
Old Aug 2, 2004 | 05:53 PM
Ditdogs's Avatar
try this...
https://honda-tech.com/zerosearch
Old Aug 2, 2004 | 05:54 PM
RidinStock's Avatar
Default Re: engines (skunk2eg)
There's a link in the top right, it says "Search". Not only that, but there is a crapload of info on the internet. Just search for these different engines: B17A, B18A, B18B, B18C1, B18C5. You'll find more info, specs, and how each works per application. It's a lot easier then posting up such a simple question.
Old Aug 2, 2004 | 05:58 PM
wishihadagsr's Avatar
You need to understand vtec... if I was you I would search that, vtec is obviously better than not but without a controller the difference would really only be noticed in third gear.
Old Aug 2, 2004 | 06:31 PM
3.504's Avatar
Default Re: engines (wishihadagsr)
ugh.... theres alot more to it then a simple 3rd cam lobe or vtec cross. for the most part (well, basically all part) the VTEC motors have a higher c/r, better bort design, bigger ports, better head characteristics, better bottom end (for reving) better fuel/timing programs and are over all a more performance oriented motor. the LS dohc vtec is simply a workhorse made to get the job done, but can be made into an excellent motor.
now back to the VTEC. how is it mostly felt in 3rd gear? just because you're in it for a long time?? lol. i have a b16 in my DA. i run it on a pr4 (ls computer) because i'm too poor for a good ecu, but anyways, i rode around no vtec for a while, didn't mind, just needed a working car. then one day i was bored, wired vtec on a switch through a relay pack for nitrous, and what a difference! 1st gear was so amazing and it felt like the motor could finally breath.
and to answer the original question: the motor codes give away rounded displacement in liters. i.e.... b18c1 = 1.8 liter and that motor happens to be DOHC vtec. b16a = dohc vtec 1.6. and theres more than just b-series family to deal with.
so there is vtec motors over 1.7 liters, theres a few quite a bit over 1.7 liters, such as c-series and j-series 6 cylinders, and the h22 2.2 liter dohc vtec along with f-series motors.
just for fun knowledge, SOHC b-series = b20a3, came in 88-89 prelude s
Old Aug 2, 2004 | 06:38 PM
Medek's Avatar
Default Re: engines (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">just for fun knowledge, SOHC b-series = b20a3, came in 88-89 prelude s </TD></TR></TABLE>
and that bastard b21a1 from the 90 prelude si. eats rings and burns oil like a bat out of hell. ::venting::
Old Aug 2, 2004 | 06:45 PM
mr.beeks's Avatar
Default Re: engines (RidinStock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinStock &raquo;</TD></TR><TR><TD CLASS="quote">There's a link in the top right, it says "Search". Not only that, but there is a crapload of info on the internet. Just search for these different engines: B17A, B18A, B18B, B18C1, B18C5. You'll find more info, specs, and how each works per application. It's a lot easier then posting up such a simple question.</TD></TR></TABLE>
what about your b18c3 and b18c6......
Old Aug 2, 2004 | 06:52 PM
3.504's Avatar
Default Re: engines (mr.beeks)
c3 and c6's were later released blocks (as crate motors) in japan or were new zealand and such motors. not released in the states... and if you see one stateside, then its pretty fricken rare and you should feel blessed, but they're just the same thing as jdm b18c gsr's
hondafdj444
Feb 13, 2014 01:13 PM
tractionless
Apr 26, 2006 11:47 AM
skrewdriver88
Jul 12, 2004 06:09 AM
xpress
Apr 15, 2004 05:52 PM
MRVTEC
May 5, 2002 08:14 PM
