engine wont start
Old Jan 8, 2008 | 04:56 PM
gsr96cx's Avatar
Default engine wont start
DAMN.....HELP ME PLEASE; ANYONE.
I just bought a jdm b18b and installed it. But when I start the car it cranks but you have to have your feet on the gas paddle so it'll be at 2000rpm or higher in order for the engine to keep running. Need help.
Old Jan 13, 2008 | 05:28 AM
FSS13foxtrot's Avatar
Default Re: engine wont start (gsr96cx)
check vacuum lines, battery life
Old Jan 18, 2008 | 04:20 AM
n e updates? fix it, still stuck?
Old Jan 18, 2008 | 05:08 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: engine wont start (FSS13foxtrot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSS13foxtrot &raquo;</TD></TR><TR><TD CLASS="quote">check vacuum lines, battery life</TD></TR></TABLE>
you might have a shot TPS, those are known to be commonly bad when purchasing/installing a motor swap
any CEL's?
Old Jan 18, 2008 | 06:06 AM
jhammond_82's Avatar
Reject Papi
Default Re: engine wont start (GRAF-FITI)
lets hear more about the gas paddle. lol. i don't think the battery has anything to do with this. its starting, and running. as for a vacuum line? what does that have to do with the battery? i'm confused.
Old Jan 18, 2008 | 09:53 AM
Default Re: engine wont start (jhammond_82)
if there is a cel for a map sensor which is commonly mistook and switched with the tps sensor, it wont run right, also vacuum lines can give you a funky idle if they have holes in them etc. i fixed this issue recently on my car, as for the battery goes i miss-read a bit. check for CEL codes and update
Old Jan 18, 2008 | 10:31 AM
ALIKZANBRO's Avatar
maybe a bad connection on the ecu... i had a similar problem cables where switched.
SlimJim25
Apr 17, 2013 01:09 PM
BoBo Racing
Aug 5, 2007 03:27 PM
03RSXTypeS
Jul 28, 2007 09:57 AM
SKDRCR
Jul 19, 2005 09:44 PM
CNS2000
Honda S2000
18
Jun 14, 2005 05:01 AM
