engine trouble
Old Jul 13, 2005 | 11:30 AM
forcefedhb's Avatar
Default engine trouble
hey whats up i a swaped DA integra with a b16.......at low rpms it sputters and stalls out..and it will restart and shut off immideatly then after a few starts it runs but will shut off or sputter at like rpms up to 4000 and sometimes wheni getup it feels like its runnin on 3 cylinders till around 4000 then takes off...but for the most part qhwn its runnin it runs strong...theronly code its throwin is an 02 senser and im replacing them today...and also i noticed the dizzy has on of the 3 bolt flanges cut off and only has 1 bolt in it...idont know what dizzy it is...maybe crx si?...dont know.....could this be the problem or do yall have any onther ideas? im about to replace the dizzy with a b16 one i guess and see how tat works....let me know whats up if any anyone knows...thanks
Old Jul 13, 2005 | 11:41 AM
BlackDAy's Avatar
Default Re: engine trouble (forcefedhb)
you have to have whatever obd matches your car. if u have a 90-91 DA, you'll need an obd0 ecu, dizzy, and injectors. if u have a 92-93, u'll need an obd1 ecu, dizzy & injectors. check to see if all that matches up first.
Old Jul 13, 2005 | 12:02 PM
forcefedhb's Avatar
Default Re: engine trouble (BlackDAy)
it is all obd0 parts...
Old Jul 13, 2005 | 12:03 PM
forcefedhb's Avatar
the dizzy wires plug up so obviously it obd0 but teh flages for the bolts dont match...one ic hacked off and it only have the top bolt in it...
Old Jul 13, 2005 | 01:40 PM
forcefedhb's Avatar
HEEEEEEELLLLPPPPP!!!!
lilhatch89
Nov 1, 2007 03:57 PM
Mr_Moos
Mar 30, 2007 10:07 PM
mycrx7
Sep 4, 2005 12:12 PM
firstgenrex
Mar 4, 2004 02:39 PM
