engine swap
Old Jan 7, 2007 | 11:44 AM
taquitoman33's Avatar
Default engine swap
i have a 1996 acura integra ls hatchback 1.8L 5 speed manual, i have put a cold air intake and a new exhaust but they don't improve the horsepower too much, i knew they wouldn't... would it be good to put a gsr vtec engine swap in my car? is there a better engine i can put in it? what would the price of the engine cost? would a turbocharger be better than an engine swap? idon't have too much money to spend
Old Jan 7, 2007 | 11:48 AM
PrinceAli132's Avatar
Default Re: engine swap (taquitoman33)
Search
k20
k24
JDM B18C5
JDM B18C1
USDM B18C5
USDM B18C1
H22/H23 (and all its variations)
B20
Ali
Old Jan 7, 2007 | 11:51 AM
JoeDaSoto's Avatar
u gotta search man.. Gsr engine is good.. Type R engine is even better.. there are many many engines you can put into an integra.It all depends on what you wanna do.. All motor or forced induction..But use the search tool on this site man or else your gonna get burned hard.
Old Jan 7, 2007 | 11:54 AM
lVlemphizStylez's Avatar
Default Re: engine swap (JoeDaSoto)
put in an h22...run low 14's and call it a day...And in reference to your question..A turbo charger would be better than an engine swap. But depending on you one may cost more than the other
Old Jan 7, 2007 | 12:06 PM
JDM_DC4_Fanatic's Avatar
I would suggest Boost, or an LS/vtec set up. If you get a gsr, type r, or B16 head, you will have the advantages of vtec without the cost of a full swap.
Old Jan 7, 2007 | 12:29 PM
Default Re: engine swap (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">I would suggest Boost, or an LS/vtec set up. If you get a gsr, type r, or B16 head, you will have the advantages of vtec without the cost of a full swap.</TD></TR></TABLE>
not if it's built right he wont...The price should come out at least the same if not more
doood's Avatar
been there done that
the cost of a correctly built and tuned lsvtec is going to be more than a full swap
Old Jan 7, 2007 | 01:14 PM
Boots's Avatar
Default Re: engine swap (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">the cost of a correctly built and tuned lsvtec is going to be more than a full swap</TD></TR></TABLE>
+1
Old Jan 7, 2007 | 01:41 PM
jdm_bones's Avatar
How much money do you have to spend, and what type of HP are you thinking about ballpark?
Old Jan 7, 2007 | 07:02 PM
93Ls-tegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taquitoman33 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 1996 acura integra ls hatchback 1.8L 5 speed manual, i have put a cold air intake and a new exhaust but they don't improve the horsepower too much, i knew they wouldn't... would it be good to put a gsr vtec engine swap in my car? is there a better engine i can put in it? what would the price of the engine cost? would a turbocharger be better than an engine swap? idon't have too much money to spend</TD></TR></TABLE>It all really depends what your budget is really but if u wanna make a little over 200 hp just force induct it.Just get some b16 pistons,intake manifold of your choice,header,and good tuning if u know ppl its alot easer to get parts all this here may cost about 4g's and just tune to like 10 psi and youll be good. (i personally like the b18a1/b1) easy to work on hard to blow up.
Old Jan 7, 2007 | 07:10 PM
doood's Avatar
Default Re: engine swap (93Ls-tegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Ls-tegra &raquo;</TD></TR><TR><TD CLASS="quote">It all really depends what your budget is really but if u wanna make a little over 200 hp just force induct it.Just get some b16 pistons,intake manifold of your choice,header,and good tuning if u know ppl its alot easer to get parts all this here may cost about 4g's and just tune to like 10 psi and youll be good. (i personally like the b18a1/b1) easy to work on hard to blow up.</TD></TR></TABLE>
did you just recommend b16 pistons and a header if he were to boost it? or did i read that wrong?
Old Jan 7, 2007 | 07:19 PM
I think you read it correctly, and I don't think 93Ls-tegra knows what he is talking about.
Ali
Old Jan 7, 2007 | 07:43 PM
doood's Avatar
Default Re: engine swap (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">I think you read it correctly, and I don't think 93Ls-tegra knows what he is talking about.
Ali</TD></TR></TABLE>
ok good. i thought i was going crazy over here.
Old Jan 7, 2007 | 08:16 PM
Folgers's Avatar
ok good. i thought i was going crazy over here. </TD></TR></TABLE>
LOL, I noticed the same thing turbo with headers 4cly?
Old Jan 7, 2007 | 11:47 PM
SiR99's Avatar
Dont SWAP your motor, because your going to spend a lot of money and your not going to be satisfied. The best advice I can give you is leave it as is. But if you HAVE TO have more power definately Boost it. It cost the same as a swap and you will have so much more power. If you keep it around 250 with a good tune you will be okay. Most people say 300whp is reliable too but it will obviously wear the motor more then 250whp.
If you HAVE TO do something, boost it, nothing else is worth the money, unless your into circuit racing and your looking for a reliable motor that can take a good beating. Then I would get a itR motor.
Old Jan 8, 2007 | 12:08 AM
redDAinteg's Avatar
Default Re: engine swap (SiR99)
I personally think you should boost your LS motor. For a practical kit to be driven daily will cost you around 1200-2000 minimum, and you going to have to find someone to tune it for you.
As for me, I'm swapping my LS engine for a b18c(gsr) and later down the road im going to boost it. i'm getting a jdm b18c for 1800$ from hmotorsonline.com and thats just the motor. You would still need an ECU or chipped ECU to run the engine. And if you don't do the work yourself, your going to be spending another $500 on up in labor to swap the motor.
I got all these figures from my own experiences from doing the same things so your numbers my vary a little more or less, but in that ball park.
Old Jan 8, 2007 | 03:33 AM
raaawrz's Avatar
You should probably wait until you have more money to spend on everything.
Old Jan 8, 2007 | 06:40 AM
aaronISthrowed's Avatar
Default Re: (raaawrz)
Boost it, it will probably be the most bang for the buck.
Old Jan 8, 2007 | 07:12 AM
tweekerz's Avatar
Default Re: (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">Boost it, it will probably be the most bang for the buck.</TD></TR></TABLE>
Sorry, the best bang for your buck is nitrous. But 3-4k will get you more power on your current setup with a properly tuned/sized turbo than any engine swap will give.
Old Jan 8, 2007 | 07:21 AM
Tizight's Avatar
You can piece together your own turbo for a little over 1200. Way cheaper than a swap. Like everyoen said a built all motor setup would cost you far more than a new swap.
Old Jan 8, 2007 | 08:27 AM
tweekerz's Avatar
Default Re: (Tizight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizight &raquo;</TD></TR><TR><TD CLASS="quote">You can piece together your own turbo for a little over 1200. Way cheaper than a swap. Like everyoen said a built all motor setup would cost you far more than a new swap.</TD></TR></TABLE>
True. Tuning will set you back $$$, but do it yourself to save on install labor.
Old Jan 13, 2007 | 09:49 AM
Default Re: engine swap (jdm_bones)
2000$ around 200hp, the more the better
Old Jan 13, 2007 | 10:00 AM
Schister66's Avatar
Man U FTW
turbo setups are the best bang for the buck on Hondas....My first setup cost me like $2900 after tuning and a clutch, but the parts were mostly new. The best thing to do is wait for a good deal and then jump on it. Also, for just shy of $3000 i made 275whp which is a lot better than any swap. My new setup is much sweeter....
Old Jan 13, 2007 | 03:35 PM
Default Re: (Schister66)
what if i enlarge the block and widen the pistons how much would that cost and how much hp would it add... would it work well?
Old Jan 14, 2007 | 01:39 PM
doood's Avatar
Default Re: (taquitoman33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taquitoman33 &raquo;</TD></TR><TR><TD CLASS="quote">what if i enlarge the block and widen the pistons how much would that cost and how much hp would it add... would it work well?</TD></TR></TABLE>
you're looking at $800+ to have it sleeved and another $600+ for new pistons and rods. that's before new bearings and gaskets and everything else. then you have to build the head to take advantage of it all.
just boost it.
