Engine Problem
Old Dec 15, 2004 | 10:00 AM
RadRonny's Avatar
Gnar By Far
Default Engine Problem
Every time i apply the gas in any gear it spudders and looses power..It jus started doing this today...any ideas??
Old Dec 15, 2004 | 10:16 AM
85mm LS VTEC's Avatar
Default Re: Engine Problem (KarmaPaymentPlan)
Have you changed your fuel filter latley?
Old Dec 15, 2004 | 10:21 AM
aznballer's Avatar
also check spark plugs
Old Dec 15, 2004 | 12:34 PM
cnydc2's Avatar
Default Re: (aznballer)
I may be your fuel pressure regulator. Does it stutter and the rpms fall even with your foot to the floor? Also check for spark and check the inside of your distributor for corrosion and see if the cap and rotor are worn out. Good luck
corys_ej8
Sep 2, 2011 06:12 PM
4d_ef_bucket
Jan 13, 2010 12:54 PM
HondaRexBoi
May 13, 2008 12:08 PM
Lonny
Apr 13, 2003 01:12 PM
Hondasaurs
Nov 2, 2002 07:21 AM
