Engine operating/water temp
Old Dec 20, 2003 | 05:40 PM
theseus824's Avatar
Default Engine operating/water temp
I have made several datalogs with my Hondata and my water temp never goes above 165degF. How am I supposed to tune if the engine is always adding cold fuel enrichment? Is there something I can do? I'm think maybe my thermostat is faulty. I have a Turbo B18B fully built and sleeved and a C&R Racing radiator. Any help or suggestions would be appreciated.
Old Dec 20, 2003 | 05:43 PM
AzG35's Avatar
Default Re: Engine operating/water temp (theseus824)
Is this on the street or on the dyno? On the street, this time of year, the motor will probably be running quite a bit cooler if you have constant airflow. If its on the dyno, it will heat up passed 165 usually if you put enough load on the motor for enough time.
Old Dec 20, 2003 | 05:51 PM
theseus824's Avatar
Default Re: Engine operating/water temp (AzSi22)
on the street, and yes on the dyno it was running normal temp. I aould have to let it idle for like fifteen minutes to get it to 170degF. How can I get it to run in its "normal" range?
Old Dec 20, 2003 | 06:17 PM
Arsenal's Avatar
new thermostat. Had same problems, fixed it.
primetime
Aug 22, 2010 07:00 PM
alexthegrinch
Oct 9, 2008 11:02 PM
theseus824
Dec 21, 2003 01:07 PM
92SiTurbo
May 30, 2002 05:54 PM
NewYorkTypeR
Jun 15, 2001 09:09 PM
