a engine no power question
Old Mar 22, 2008 | 02:51 PM
rotascircuit's Avatar
Default a engine no power question
Hey I got a 93 acura integra manual. The other day my distributor went out and I changed it with the cap and rotas and the spark plugs with wires. When I started the car, I drove it and gave it gas and I was amazed. When I punched it on low RPM's, the car did not even go until it got into higher RPM's. The timing is perfect. I checked it. So what I am thinking is the fuel or too much air and not enough fuel. so basically when on low RPM's it does not jerk, it just has no power until high RPM"s. What can it be? What can I check? ANYTHING IS A THANK YOU (only if is not crap and jokes) PLZ NEED HELP THANX
Old Mar 22, 2008 | 05:46 PM
PerfectTechs's Avatar
Default Re: a engine no power question (rotascircuit)
make sure your firing order is correct. You might have rotated your distributer assembly also, this will mess up your timing, make sure you didnt rotate the entire assembly.
Old Mar 22, 2008 | 08:54 PM
94DB8's Avatar
its a honda we dont make low end power lol but ya just make sure you havent crossed any of the wires, check your air filter it may be really dirty and/or clogged
Old Mar 22, 2008 | 09:40 PM
Default Re: (94DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DB8 &raquo;</TD></TR><TR><TD CLASS="quote">its a honda we dont make low end power lol but ya just make sure you havent crossed any of the wires, check your air filter it may be really dirty and/or clogged</TD></TR></TABLE>
btw I took off the pipe and it was the same thing
Old Mar 23, 2008 | 08:27 AM
BoSox46GSr's Avatar
Default Re: (rotascircuit)
Well how low of RPM's does it not make power, and when do you notice a signifficant pickup in power? If it didn't do this before, a tune up should only make it better. You must have not done something right. Check your fuel filter too.
Old Mar 23, 2008 | 11:08 AM
Default Re: (BoSox46GSr)
hey bro like before 3 or when its idling u floor it and it has very slow response never before done that
Old Mar 23, 2008 | 02:07 PM
BoSox46GSr's Avatar
When you took the dizzy off, did you put it back on in the same spot it came off? You might have just retarded it. Always mark where the bolt lines up in the relation to the head.
Old Mar 23, 2008 | 02:28 PM
ok THANX
Old Mar 23, 2008 | 04:28 PM
all-mtr-teg's Avatar
Check the spring that makes contact between the coil and the cap. Either that or check the resistance on the coil to see if its in spec.
Old Mar 23, 2008 | 06:52 PM
g2daturbo's Avatar
Default Re: (all-mtr-teg)
get a timing light and check ignition timing.... or bring it somewhere if you dont know what ur doing but def sounds impoperly adjusted ignition timing...
Old Mar 23, 2008 | 08:56 PM
It really sounds like a faulty coil. Just cause you installed a new or rebuilt dizzy, doesn't mean it can't be defective. Check the primary and secondary resistances on the coil.
AudioFunk
Dec 26, 2013 12:42 PM
rotascircuit
Mar 22, 2008 11:29 PM
killaj12
Aug 14, 2005 12:28 AM
Donovan
Jan 6, 2004 04:23 PM
blulude92
May 4, 2003 04:05 PM
