Engine mount relocation??
Old Dec 24, 2013 | 06:11 PM
  #26
B_Swapped93's Avatar
Default Re: Engine mount relocation??
Originally Posted by awesomeguy641
Acually there is a point of putting a fully built d- series in a integra. Believe it or not. A turbo fully built dseries will spank a fully built turbo bseries. Less rotation. Less weight to hull. And there was a awd dseries tranny in the ef waggons. So in other words d-series are faster built. Bseries are only good from.the factory.
Just stop there....I'm not even going to try and argue that point when the fastest drag cars are DOHC engines. Tell me a built 400whp d-series is faster then a 900+hp K20. infact I'll just leave this here
Old Dec 24, 2013 | 06:15 PM
  #27
I will literally continue to post B/K series Honda engine videos that will wreck supra's and GTR's (700hp civic dominates the street).
Old Dec 24, 2013 | 07:53 PM
  #28
kaycee_00's Avatar
Old Dec 24, 2013 | 09:36 PM
  #29
doood's Avatar
been there done that
i guess speedfactory will do 6's with a turbo d then, right?
shut the **** up
Old Dec 25, 2013 | 03:23 AM
  #30
JDMFLUSH1's Avatar
Originally Posted by dc_jdm_dreams
It should be easier to modify your existing mounts. This will prob not give you a 4 inch raise but I guess some raise would help. Making a spacer for the rear "t" mount and taking some material off of the bottom of the driver side mount. The hardest thing would be the trans mount. But if you have access to a machine shop it will help. I am thinking chopping off the whole bottom area of the trans mount along with some material then fabricating a plate with the same mount holes trans to mount. Then welding it back on there. You might be able to get 1/2 or maybe even a 1" lift out of that. Combining that with a custom sump oil pan that should put you in the clear. I personally dont agree with this but your car and your money. Would be cool to see the Fabrication work in making these one off mounts.
I was thinking somewhere along those lines. thanks!
Old Dec 25, 2013 | 03:25 AM
  #31
JDMFLUSH1's Avatar
Originally Posted by B_Swapped93
This crossed my mind, a great idea but only thing is the guys who want to be slammed don't know what a dry sump set up is at all. And more then likely can't do the set up them self's along the exhaust would still be an issue, but in theory but to that I'd say get a side exit header like a drag car lol.
u are correct. I know not of what a dry sump is at all. care to elaborate? or point me in the direction?
Old Dec 25, 2013 | 03:28 AM
  #32
JDMFLUSH1's Avatar
Originally Posted by JDMswagSerf
You can weld 4" tall steel plates to the current engine mount places(obviously 2 plates on each mount)
How ever up high the holes on the plates are, will determine how much it is raised
2 plates would be sketchy.
I would also well supporting plates on the 2 plates.
2 plates going from the top of the 2plates that are for the engine, going to the body.
Then another 2 plates holding it in
So 2 plates holding the engine, and 2-4 supporting plates for each of the engine plates.
As for the T bracket, leave it bolted to the block as is, then run 2 more plates from the bracket to the mount on the crossmember, then just put the bolts through the plates.
Vibration mounts will have to be removed
All this is being pictured perfect in my head lol
Hope you understand.
Also I am not sure of the strength this will have, idk if the plates will hold up.
But with a good welder and skills, that can be done.
thank youuuuuuu!!!!!
Old Dec 25, 2013 | 11:25 AM
  #33
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
You're welcome!
If you do do this. Or whatever you do, take lots of pics and show us!
Old Dec 25, 2013 | 11:30 AM
  #34
Shit Posts: 15
10 Year Member
http://auto.howstuffworks.com/fuel-e...uestion331.htm
Originally designed for race cars, have them about 3 more inches to lower their engine to lower the center of gravity of the car for handling.
But you can use this system for 3" oil pan clearance from the ground.
Will be pricey though
Old Dec 29, 2013 | 11:26 AM
  #35
JDMFLUSH1's Avatar
[IMG][/IMG]
[IMG][/IMG]
this is how it sits now..
Old Dec 29, 2013 | 12:36 PM
  #36
doood's Avatar
So you want to go through the hassle of raising the engine because you're slammed?
Lol ******* kids
Old Dec 29, 2013 | 01:15 PM
  #37
Shit Posts: 15
10 Year Member
What suspension do you have
Old Dec 29, 2013 | 01:35 PM
  #38
at steels with hub caps, if you do figure out how to raise the engine it'll more then likely be a hack job. fail to see how you'd raise the trans mount....
Old Dec 29, 2013 | 01:36 PM
  #39
JDMFLUSH1's Avatar
Lol ******* kids
get the **** off my thread then bitch. easy to sound like a bad *** when you're hiding behind a computer
Old Dec 29, 2013 | 01:41 PM
  #40
JDMFLUSH1's Avatar
ebay "coilover sleeves" all around. oem s2k shocks in the rear. the back rides beautiful but I'm gonna put koni yellows with extended tophats on the front soon... I aready cut the shock tower. got another set of front LCA's with poly bushings... just waiting for the front shocks really
Old Dec 29, 2013 | 01:43 PM
  #41
JDMFLUSH1's Avatar
time will tell son.. I will post up pics as soon as I start executing this project
Old Dec 29, 2013 | 01:57 PM
  #42
ebay sleeves and cut towers why ! my tack car sits maybe 3/4'' higher and I didn't need to do that doesn't hit at all. Why not a 15x9 rim on there with stretched tires ?
Old Dec 29, 2013 | 04:21 PM
  #43
Shit Posts: 15
10 Year Member
What method will you go about with on raising the engine?
Old Dec 29, 2013 | 04:23 PM
  #44
JDMFLUSH1's Avatar
15x9 is my goal. idk what u want me to tell you, my upper ball joint was hitting the shock tower so I had to cut it yo
Old Dec 29, 2013 | 07:36 PM
  #45
JDMFLUSH1's Avatar
that's what we are trying to brainstorm about
Old Dec 29, 2013 | 07:41 PM
  #46
doood's Avatar
And its real easy to look like a total sheep when you make threads like this with a car like yours.
Edit: of course you would cut holes in your strut towers
Edit 2: let's be real here, you're not gonna do anything except sell the car for some ridiculous amount after you realize how bad you've already fucked it up, and still claim it's a clean car and runs great.
Old Dec 30, 2013 | 06:57 AM
  #47
Schister66's Avatar
Man U FTW
Physics isn't going to like this. If you raise the engine a few inches in the front end (regardless of your reasoning) you're moving the center of gravity for the front end of the car upward. This has all kinds of adverse handling and tirewear implications, but that's a story for another day
The other issue you may have is that the axles may not articulate enough to reach the new engine position; moreover, if you move the engine upward, you may need longer axles to reach the hubs or risk separating the CV joints.
Lol ******* kids
I dont get this whole "stanced" bullshit...i like to drive my car without the oil pan eating up every bump. Raise your car to a normal height and you wont have to worry about this. Also, dont bother with a dry sump system...a retrofitted system will cost you as much as that Teg did
Just stop...
Thanks for your comment, but it was neither helpful nor accurate.
Old Dec 30, 2013 | 08:52 AM
  #48
JDMFLUSH1's Avatar
Just stop...
thanks for your in put man. I mean theres a ton a factors I gotta take in. my wheel hubs are at a higher point than my tranny so my axles are at an opposite angle than they were from factory which is why I am in favor of raising the engine... butt I also gotta see which size wheels ima keep too as it will affect that.
Old Dec 30, 2013 | 09:57 AM
  #49
Schister66's Avatar
Man U FTW
How is this going to fit under the hood? IIRC, there isn't 4" of clearance between the valvecover and hood
Old Dec 30, 2013 | 10:29 AM
  #50
doood's Avatar
Cut a hole in the hood, duh. Op isn't opposed to needlessly cutting holes in things.
