Engine Model?
Old Sep 18, 2003 | 02:53 PM
n0 iNTegRiTY's Avatar
Default Engine Model?
Hey, I know this is kind of a stupid question, but I know theres somewhere in the engine bay that says what model engine the car is equipped with.... Where is it in the Tegs? Thanks.
Old Sep 18, 2003 | 03:04 PM
mr.beeks's Avatar
Default Re: Engine Model? (n0 iNTegRiTY)
the label is on the back of the hood ussually you will find a lot info
engine famaly, plugs to use vacuum diagram and AC info as well
Old Sep 18, 2003 | 03:23 PM
StatGSR's Avatar
Default Re: Engine Model? (big reds)
if u have a GSR you have a B18C1, there is a little plate that says that right on the front of the engine, it is just to the left of the heat sheild that is over the header.
Old Sep 18, 2003 | 03:54 PM
4crx4me's Avatar
Yes it's called a VIN. In the VIN there is "digit" that signifies what engine came with the car from the factory originally. It's in a code however and you need the Helms to decypher it.
The VIN is stamped in 3 places: On the top edge, in the middle of the firewall. On the VIN plate on the dash, just inside the drivers A pillar.
And on the edge of the drivers door or door jamb.
HTH
Not sure if this applies to 1st or 3rdG tegs, or only the USDM and Canadian 2G's
DA9-1.8L
DB1-1.8L
DB2-1.7L
Old Sep 18, 2003 | 04:03 PM
Default Re: Engine Model? (orange_civic)
Ahh, found it, I knew the engine model but I just couldn't figure out where the damn thing says it... Long story-short, just tryin to prove a friend wrong. Thanks for the help
Crew Chief
May 2, 2020 03:37 PM
Kmech
Apr 6, 2012 12:44 PM
Niev0000
Honda Civic (2001 - 2005)
Nov 17, 2011 06:12 AM
davidcrevenston
Mar 26, 2010 11:32 PM
