engine light flashes
Old 05-25-2017, 12:55 PM
SGarrett's Avatar
Default engine light flashes
11 or 12 times .... it flashed and then went off??? generally reclicking the gas cap turns off the engine light ... just before getting gas just now .. Any standard meaning there?
Old 05-26-2017, 05:13 AM
O.G. triple O.G.
NVturbo's Avatar
Default Re: engine light flashes
misfire. Could be as simple as bad gasoline to bent valves.
Old 06-01-2017, 11:59 PM
trm4life's Avatar
Well, the CEL (check engine light) will typically flash of your reading a code. I'd start with trying to see if there's a code stored. It very well could be the gas cap (sometimes will come up as evap emissions control) that's causing a problem. If the system detects an air leak, it will throw up that code. Likely causes are fueling without shutting off your car, or just a bad or loose gas cap. You should never leave your car running while fueling. It keeps the exhaust hot and raises potential for fire if there's a spill, it's bad for your fuel system, because it's PRESSURIZED (hence fuel pressure regulators! ) and puts you at high risk to get your car stolen!
Accord-Guy
03-12-2009 06:37 PM
civ05se
Honda Civic (2001 - 2005)
16
06-21-2008 11:21 AM
londonsupra
07-07-2006 05:30 PM
ckyguy
07-08-2004 04:11 AM
SuPeRITR
03-18-2003 06:02 PM
Quick Reply: engine light flashes
