Is this engine kit any good?
Hey looking at buying this engine kit would anyone recommend it? Would the pistons handle 10-15psi without causing me any problems? I also have Eagle H beam rods i'll be using to. Any help would be great thanks.
http://www.ebay.com/itm/New-Acura-In...#ht_3505wt_932
As simple as I can put it: NO.
That's all junk unless you find a CP/JE and Manley rod combo. Pair those up with OEM rod bearings, OEM gaskets, and OEM Honda filter and you have a reliable setup. A good piston set alone costs more than that all that stuff together, so that alone should make you not trust it.
I've heard good things about the pistons but I wouldn't use them if I had forged rods. Do some research you'll see some good things about NPR pistons and rings, all the other stuff is junk
For gods sake, a set of CP pistons, arguably one of the best, retails for $600. You cant honestly tell me that someone would trust a WHOLE rebuild kit, including pistons for 350. Cmon now, it's common sense. Regardless what people say, those pistons are crap. Period.
I didn't say they were as good as cp but they arent crap. Like I said in my first post research them not say their crap cuz they are cheap
No I'm not saying I'd recommend them for OP with that much boost and forged rods
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/npr-pistons-piston-rings-2569157/
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/npr-pistons-rings-vs-oem-honda-pistons-rings-difference-1875278/
sudden impulse
Aug 2, 2017 05:16 AM
Redneck_Tuner
Sep 22, 2011 02:40 AM
