engine is hot when its cold
Old May 8, 2007 | 07:31 PM
faridos's Avatar
Default engine is hot when its cold
hey my engine is reading that the oil is extremely hot when i know that the engine is dead cold. any suggestions?
Old May 8, 2007 | 07:46 PM
numbnuts22715's Avatar
you dont need to post 2 threads asking the same question..
Old May 9, 2007 | 11:27 AM
Sam92Teg's Avatar
Default Re: engine is hot when its cold (faridos)
Do you have an oil temp gauge, or are you talking about the oil pressure warning light coming on?
Old May 9, 2007 | 03:24 PM
1DA9's Avatar
try changing temp. censor
Old May 9, 2007 | 08:54 PM
blakacintegra's Avatar
Default Re: engine is hot when its cold (1DA9)
make sure gauge is reading correctly
replace if needed
Old May 20, 2007 | 10:46 AM
faridos's Avatar
Default Re: engine is hot when its cold (blakacintegra)
well the problem was solved. the engine temp sensor was blown out. From what it looked liked the wire was thought to be the problem. I checked out the voltage on it though and it turned out fine. I finally bought the sensor and fixed a very small problem thrown out of proportion.
jack cohen
Jul 25, 2017 05:51 AM
Luke_2089
May 13, 2014 07:55 PM
Charlie Moua
May 21, 2013 05:08 PM
PinoyEJ6
Oct 3, 2007 10:22 AM
