engine help
Old Nov 24, 2013 | 03:21 PM
Brandonb92's Avatar
Default engine help
hello i have a 97 integra obd2 and the motor went so will a b18 out of a da integra work with my car or no i was told i will have to use my knock sensor along with my intake and fuel injectors along with fuel rail. also is there any other engines compatible with my car without having to do the engine harness and ecu swap and stuff like that just plugand play
Old Nov 24, 2013 | 03:42 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: engine help
Reuse your distributor, alternator and injectors. Intake manifold swap as well. Neither engine uses a knock sensor unless your car is a GSR. Also you'll need to wire the fan switch to the back of the block. You'll need to do the CKF bypass, search for that on goggle and you'll see how. Honestly though in most states it illegal emissions wise to swap older engines into newer cars.
Coupe16vt
Dec 31, 2017 03:22 AM
dcletten
15
Apr 5, 2012 08:04 AM
acuradude2006
Apr 21, 2006 05:18 PM
Integman1990
Jan 9, 2004 01:17 PM
