Engine Fan keeps Running !! Help !
Old Jan 16, 2006 | 02:15 PM
Elbowpunk's Avatar
Default Engine Fan keeps Running !! Help !
The radiator fan keeps running after i shut my engine.... and keeps goin for like 30-34 mins... sometimes i get worried and turn the car on...but not start it and turn it off... sometimes that works... i checked all fuilds are fine...
Whats goin on here ??
I live in Phoenix, Arizona its kinda cold... not too bad ever did this before
Old Jan 16, 2006 | 02:19 PM
veggiemaster's Avatar
Default Re: Engine Fan keeps Running !! Help ! (Elbowpunk)
More than likely its the fan relay or a temp sensor. My old DA use to do that and it ended up being the fan relay, but ive also heard of a coolant temp. sensor being a culprit of that.
Old Jan 16, 2006 | 03:04 PM
92DAIntegraXSI's Avatar
my car does the same exact thing. its the fan timers/relays there 3 under the hood u can get them from the dealer maybe aftermarket . i havent gotten around to changing mine yet but i know its that
Old Jan 16, 2006 | 03:59 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: Engine Fan keeps Running !! Help ! (92DAIntegraXSI)
wow my DA does this to
Old Jan 16, 2006 | 04:00 PM
Default Re: Engine Fan keeps Running !! Help ! (stocker2shocker91)
did they ever have a recall on this?
Old Jan 17, 2006 | 09:54 AM
maniach4x's Avatar
haHA my old prelude did this too. to just stop it I removed my relay mmm should of replaced it, never did.
Old Jan 17, 2006 | 08:16 PM
Elbowpunk's Avatar
Default Re: Engine Fan keeps Running !! Help ! (maniach4x)
damn .. anyone knows how to do it.. .how much part cost ?? what does this fan acually do ?? i herd ppl say all kinds of crazy ****...
any help would be great !
Old Jan 18, 2006 | 06:30 AM
well i work for acura ill try and get a price on them for you retail of course. its pretty important fan. i blew the fuse to it once when installing my alarm and i drove for like maube 15 minutes looked down and saw the temp gauge go to almmost red so yea its important
Old Jan 18, 2006 | 09:43 AM
M Coop's Avatar
If you wanna make sure if it's the relay swap out the relay with another one, that should help you narrow down the problem. There are several identical relays in your car. BTW, is it the one for the AC or the one that cools the engine? You can unhook the one for the AC until summer time and get away with it but I wouldn't just unhook the one for the engine.
Old Jan 18, 2006 | 01:52 PM
Elbowpunk's Avatar
Default Re: Engine Fan keeps Running !! Help ! (M Coop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M Coop &raquo;</TD></TR><TR><TD CLASS="quote">If you wanna make sure if it's the relay swap out the relay with another one, that should help you narrow down the problem. There are several identical relays in your car. BTW, is it the one for the AC or the one that cools the engine? You can unhook the one for the AC until summer time and get away with it but I wouldn't just unhook the one for the engine. </TD></TR></TABLE>
ya...duh but how ?
Old Jan 18, 2006 | 06:51 PM
Elbowpunk's Avatar
OK... now the engine check light turned on tonight... could that be the answer to the fan ??
Ahhhh !!
Old Jan 19, 2006 | 07:12 AM
M Coop's Avatar
Depends, what codes is it giving you? What do you mean but how? Do you know what the relays look like and where to find them? And do you know if it's the AC or the one for the engine coolant that keeps running?
Old Jan 19, 2006 | 08:08 AM
DarkDragon's Avatar
mine does this as well. Ill check and see if its the Ac or engine cooling fan. I dont know where the relays are though. I have a hynes manual but it sucks
Old Jan 19, 2006 | 08:32 AM
M Coop's Avatar
Default Re: Engine Fan keeps Running !! Help ! (DarkDragon)
OK, the relays are in a couple locations (to all the flamers out there F off if I'm off by a couple inches alright, cause ya'll never have anything to say when people need help just when you wanna talk **** and tell people to look it up) Anyhow, basic description of the relays, they're little black approx. 1.5 inch by 1 inch, they have a little metal tab with a hole in it which is how they're mounted, you'll generally find them mounted close to the core suppore (kinda under the headlights) but don't confuse them with the headlight relays. They have a little rubber boot protecting them, and a 3 or 4 wire plug, plugged into them. Best way to be sure of which relay you're looking at is to just trace the wire from the fan until you find them. Might be easier to find it from underneath if you take the plastic panel/splash guard off. Should be one on the passenger side for the engine coolant fan and don't quote or F'ing flame me but I think the AC fan relay is on the driver side of the radiator held onto the support with a 10 MM bolt. As long as they're identical, you can swap one out for the other and narrow down the problem that way. If the fan keeps running with a different relay you probably have a different problem.
Old Jan 19, 2006 | 04:05 PM
Elbowpunk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M Coop &raquo;</TD></TR><TR><TD CLASS="quote">Depends, what codes is it giving you? What do you mean but how? Do you know what the relays look like and where to find them? And do you know if it's the AC or the one for the engine coolant that keeps running? </TD></TR></TABLE>
Code ?? i have no idea what u are talkin about LOL ... i dont kno much about cars... but i kno its the fan by the headers and raditor spinnin so i have no idea... LOL thank you guys for stickin with me on this .. .!!!
Old Jan 19, 2006 | 07:10 PM
CRXb18Turbo's Avatar
Mines does the same... It don't bother me... As long it don't drain my Battery or overheat.
Old Jan 20, 2006 | 03:21 AM
M Coop's Avatar
You said the Check engine light came on right? If you have CEL you need to jump the little blue plug that's down under the glove box (just put a wire from one side of the plug to the other, turn on the ignition (not all the way on just like a click or two) then look at the flashing light next to your speedo, count the number of times it flashes, then cross reference the number of flashes with a helms or haynes or chiltons manual. BTW, long flashes count as 10, quick flashes count as 1.
Old Jan 20, 2006 | 06:13 AM
Elbowpunk's Avatar
^^ Woah does this have it on the 91 tegs ?? cuz W0w im stunped and dont know what r talking about
Old Jan 20, 2006 | 06:53 AM
M Coop's Avatar
OK I think your car, what you need to do is pull back the carpet on the passenger side, turn the key on to the 1st or 2nd click, and just look at the little blinking red light on the floor board same basic thing applies regarding the flashes, don't think you need to jump the blue plug in your case.
zx92027xz
17
Sep 29, 2024 09:55 AM
PhilipS
Honda Civic (2001 - 2005)
Jun 22, 2017 02:36 PM
xpdude
Nov 5, 2009 05:39 PM
FONK
Jan 12, 2006 03:03 PM
FONK
Jan 11, 2006 08:48 PM
