engine buzz
Old Jan 6, 2006 | 10:40 AM
groundpounder's Avatar
Default engine buzz
I just bought a '96 GSR 5spd with 120k on it. There is a metallic buzzing noise coming from the front of the engine. It happens lightly at 1500 and much louder at 3000 rpm. It's very rpm specific and only lasts about 100rpm. It does it either driving or sitting in the garage.
The car had a head gasket and valve job at 110k done by an Acura dealership.
It had a new water pump and timing belt at the same time.
There don't seem to be any loose heat shields or hoses or anything. It really sounds like it's coming from the area of the timing belt cover. Anybody else run across anything like this?
Thanks for any info.
I've also got some questions about cold start idle speeds that I'll save for another post.
Old Jan 6, 2006 | 11:00 AM
b20integrapower's Avatar
Default Re: engine buzz (groundpounder)
i had the same exact problem...never figued it out cuz it just went away...bump for this guy...its really annoying..
Old Jan 6, 2006 | 11:29 AM
Default Re: engine buzz (b20integrapower)
I kinda suspect the timing belt tension spring but don't really want to tear the covers off without some moral support.
Did you just have a timing belt put on or anything?
Hawkerdude
Oct 31, 2016 05:30 PM
BLKFLSH
Dec 20, 2011 11:30 AM
dce
Aug 24, 2007 07:20 AM
dynamyks
Aug 12, 2005 06:38 AM
imports
Jun 25, 2003 11:44 AM
