Engine bogs and dies
Old Mar 19, 2003 | 10:12 AM
Mr Samson's Avatar
Default Engine bogs and dies
Hey, I have a 98 gsr and I have a problem that sometimes when i turn on my car it struggles to turn on and i have to keep giving it gas for about 30seconds-1minute, if i don't the revs go under 1g and it struggles and dies. By itself it never goes over 1g, as in the car doesn't attempt to keep the revs up when i turn it on, i always have to manually press the gas. I have intake, jg header(missing an exhaust bolt from header to cat and it is leaking air), greddy evo, 95 obd1 ecu, skunk 2 intake valves(installed by jotech which I believe they could have fucked up) They cracked my gauge cluster and denied it!
Old Mar 19, 2003 | 10:17 AM
DeadLock23's Avatar
Default Re: Engine bogs and dies (SiRiusRcr214)
maybe there is something wrong with the idle, usually the ECU will tell the engine to idle at higher RPMs to warm up when you just start it.
it might also be something with the fuel delivery.
I'm not sure, but those are some of the ideas that come to mind.
goodluck working things out.
Old Mar 19, 2003 | 10:22 AM
neo1z's Avatar
Default Re: Engine bogs and dies (DeadLock23)
Is that ECU of yours chipped?
Old Mar 19, 2003 | 09:25 PM
Mr Samson's Avatar
Default Re: Engine bogs and dies (neo1z)
Nope
Old Mar 19, 2003 | 09:35 PM
NiChRiS's Avatar
Nope
have you checked your plugs, wires, cap and rotor? is your O2 sensor ok? is there a check engine light? how many miles on car...
Old Mar 19, 2003 | 10:34 PM
Mr Samson's Avatar
Default Re: Engine bogs and dies (NiChRiS)
the check engine light has came on once but it turned off, 82000, how do i check if the o2 sensor is ok?
Old Mar 19, 2003 | 10:56 PM
intekragsr's Avatar
OMG same exact crap happen to me tonight.
If your check engine came on, jump the service connector, and I bet you will get a code 14. That is the IAC or EAC. I have not figured it out yet because I am so damn frustrated from being in the garage for about 20 hours today and yesterday combined. (seriously)
Ill try to figure it out tommorow and help you out. Goodnight
Old Mar 20, 2003 | 09:17 PM
Mr Samson's Avatar
Default Re: Engine bogs and dies (intekragsr)
u have a ecu?
Old Mar 23, 2003 | 09:43 PM
Mr Samson's Avatar
any luck?
Old Mar 24, 2003 | 11:33 AM
Mr Samson's Avatar
I really need some insight on this problem, I wanna get it fixed asap but I wanna make sure that I know what is going on when I take it to the shop.
Old Mar 24, 2003 | 01:50 PM
batman21's Avatar
the same thing happenes to me. i have a 92 ls with 158k miles. it always bogs and dies after it is parked for a long period of time. so hopefully what ever you do to fix urs will also fix mine
Old Mar 24, 2003 | 08:38 PM
Mr Samson's Avatar
Default Re: Engine bogs and dies (batman21)
I am gonna switch out the ecu
gotvtc
Apr 28, 2011 11:42 AM
alacard
Mar 12, 2009 05:56 PM
LuckyStrikes
Aug 21, 2003 11:20 AM
