engine bogs
Old Mar 12, 2006 | 05:26 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default engine bogs
i just finished swaping out my b16 for an ls and the ls is bogging really bad , not where it cuts off, i have already check the comp. and it was 180 on all 4 on 5 turns, tried several different tune cant figure it out.
any suggestions would help. already swap iacv, and valve under throttle body (cold start). checked the timing.
please help.
thanks
Old Mar 12, 2006 | 06:23 PM
WhoDoYouThink's Avatar
Default Re: engine bogs (turbob16EF)
how is it bogging? under how much load and how bad?
Old Mar 12, 2006 | 06:33 PM
turbob16ef's Avatar
Default Re: engine bogs (2000turbogsr)
it is like bogging like the timing is off but i have already redone it. it is usually around the lowwer rpm from idle to about 3 to 4. and then after that there is no power at all from the engine. rpms rise but the power stays the same. shake the entire car crazy
Old Mar 12, 2006 | 06:36 PM
that is a weird situation. I don't know what it could be, but I know a guy who is VERY good with honda motors. His name is Donny and he owns Import Specialty Automotive in tacoma, WA. Give him a call and ask him if he has any idea what it could. the number is 253-473-2606. seriously, this guy should be able to help you out better than most.
Old Mar 12, 2006 | 06:43 PM
turbob16ef's Avatar
alright thanks for the help and ill try and call him thanks for the #
Old Mar 12, 2006 | 06:45 PM
no problem man, i know how frustraiting that **** gets when you cant figure out what the hell is wrong with your car. good luck, i am sure donny will be able to help you or at least point you in the right direction and give you some ideas.
Old Mar 12, 2006 | 06:46 PM
rkrone's Avatar
check the (electrical) plugs by the throttle body/IM, they can be easily swtiched (i did this once)
Old Mar 12, 2006 | 06:57 PM
turbob16ef's Avatar
Default Re: engine bogs (rkrone)
which ones are you talkin about. tps and something else
Old Mar 12, 2006 | 07:23 PM
rkrone's Avatar
yes, there are a few clips that fit multiple connections, just check them all, maybe switch them, if it dosnt fix it, switch back
Old Mar 12, 2006 | 07:26 PM
turbob16ef's Avatar
alright will try thanks for the advice
jschettini
Jul 16, 2010 02:55 PM
turbob16ef
Mar 13, 2006 04:50 PM
turbob16ef
Mar 12, 2006 06:44 PM
