Emission/SRS light?
Would it be a problem if i was to take my emission test with the SRS light on? would they fail me? i took the air bag fuse out a while ago because my tailight went out and after that i replaced the airbag fuse with a new 1 but it doesnt seem to go away is there a way to get rid of it without pulling the bulb out?..its a 97 LS
Modified by DynastyRacer22 at 5:00 AM 3/9/2006
Modified by DynastyRacer22 at 6:39 AM 3/12/2006
reset your ecu...the light should go away. I don't believe the check engine lights go away after the problem is fixed, you still have to reset the ecu and if the light comes back than it is truly something else. Try resetting it for starters.
I’m not familiar with Washington state emission testing policy, but if all they are testing is emissions, then the Standard Restraint System (airbag) have nothing to do with it.
yeah just got my emission test done..i guess cuz my car is obd2 they only plug some kinda computer cable under neath my glove box and i passed
mikeyboost
Mar 26, 2008 08:45 AM
smiley02190
Apr 15, 2002 12:39 PM
