Eibach Pro System Plus?
Old Aug 22, 2012 | 05:14 PM
JDL2Z's Avatar
Default Eibach Pro System Plus?
I have a stock 94 integra LS. All the bushings in the suspension are worn to hell. So im redoing the whole suspension. I want a complete suspension package to do it right the first time around. No mixing and matching parts. I saw the Eibach Pro system plus. It comes with springs, shocks, swaybars, and everything else needed to install I assume. Is this a good kit? Will I need anything else? I saw that eibach also sells an adjustable upper control arm for the front and rear. Will those be needed? The front arm is pretty expensive by itself at around $350. Thats not including the cost of the pro system plus which is about $1100. I want a car that handles like its on rails but yet is comfortable enough to drive the ***** off of it. currently my suspension feels like its about to come loose at any moment
Old Aug 27, 2012 | 01:45 PM
Jackson's Avatar
Default Re: Eibach Pro System Plus?
The Pro System Plus is a great kit that will really tighten up the feeling of the car. Eibach also offrs the Sport System Plus which is the same package but with Sportline springs instead of the Pro-Kit.
I used the Sport System on my Civic before I turned it into a dedicated track car. I commuted 100+ a day and the ride was great! I would recommend upgrading major bushings like the rear trailing arm bushings and front compliance bushings for added performance and feel with OE Honda, Mugen or even Hard Race. Replacing the ball joints and tie rod ends are also a good idea if you plan on doing "everything."
The front upper control arm is not necessary but I would highly recommend replacing the rear upper arm with the adjustable unit.
vrrodri
Dec 22, 2015 04:41 AM
Atomic_ShoGun
Suspension & Brakes
Nov 28, 2011 06:52 PM
JDM CTR '00
Other Make Vehicles
May 31, 2008 12:01 PM
OppositeOfFast
Feb 2, 2003 10:48 AM
Radex
May 21, 2002 04:05 AM
